Old 06-12-2018, 05:11 PM   #8
Originally Posted by BennyLava View Post
Not gonna harm the shocks or the ride any? I was trying to make sure I avoid messing up the shocks/struts.
All this does is change the height, right? Do I need to get an alignment afterwards? Have toe/camber adjusted? Again trying to do only the 1 inch.
Any lowering spring will alter the ride quality as they're stiffer springs compared to the OEM springs. Also, any lowering springs will reduce the lifespan of the dampers (shocks). So if your car already has some higher mileage to them, you'll have to pull out the suspension twice (once for installing the springs, and another to replace the dampers when they blow).
Any adjustment to the ride height will require an alignment afterwards. Only the front of the Yaris is adjustable. The rear are not unless you use shims.
If all you're looking for is an inch drop and you have higher miles on the car (means most likely the dampers are nearing the end of their life), I would suggest getting some basic coilovers like the Tein Basis Z. They're basic coilovers in that they don't have dampening adjustment, but at least the dampers are valved/paired correctly for the spring rate. And you can dial in just how much lowering you want (within the range it provides, which is a little under an inch min to a little under 2 inches max).
Please post pics of your Yaris with aftermarket rims here grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1800 11-12-2025 12:57 PM
TRD Sport Shocks, Lowering Springs & Sway Bar Blue Beast Cosmetic Modifications (Exterior/Interior) 18 10-29-2012 04:39 AM
fs stock springs and struts, shocks XyresicPsych Items for Sale by private party 10 05-04-2012 08:34 PM
for trade lowering springs for stock rs 2007 mfvantol Items for Sale by private party 5 09-24-2011 08:30 PM
TTE / Eibach springs + stock shocks & 15" wheels DieselPower Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-11-2009 02:42 PM
