![]() Drives: 2010 Yaris Seden Join Date: Aug 2018
MT Plug Crush Gasket
I have a 2010 Yaris with a 5-speed manual Transmission. Getting ready to do a drain and fill of the tranny oil and was hoping to pick up a new crush gasket. Was wondering if anyone had a part number or anything to help me find one.
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
If the crush washer isn't leaking now then I wouldn't worry about replacing it when you change the transmission fluid. Officially the crush washer is one time use but in reality you can reuse as long as it hasn't been over-tightened before.
If the gasket is rubber coated use it. Wifes Camry with 161k has the origional drain plug gasket. No leaks.
Copper crush washers are obsolete.
Good to know that the OEM gasket isn't copper trash. Service Manual says to replace so I was concerned.
You should be fine reusing it like other stated. I've done plenty of drain and fills on mine and have never had any leaks and I've never replaced the washer
| crush washer on drain plug? | 2007yariz | DIY / Maintenance / Service | 17 | 10-06-2024 02:10 PM |
| Wires Inside the Yaris & What They Do | The Architect | DIY / Maintenance / Service | 149 | 10-18-2022 03:32 AM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| bit of spark plug insulation may have fallen into cylinder | alagappan the proud | DIY / Maintenance / Service | 20 | 01-09-2014 06:10 PM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
