Old 09-06-2020, 06:02 PM   #1
Pinchlite
Drives: 2007 yaris HB
I fixed inner front fender rub...
Drill hole between these.
https://i.imgur.com/18VUnSC.jpg
Pull out and insert bolt.
Bought me 5 mm or so.Perfect!
I could go more and it does not effect fit or finish of bumpercover or around headlights.
https://i.imgur.com/hAVynVC.jpg
Bounus pic!
Color matched cowling..
https://i.imgur.com/nBd8Q6I.jpg
Disregard A pillar with panel sticking out.
I forgot bolt when I had fender off.
I will fix ASAP.
Perhaps this is an old known hack/trick?
If not just wanted to share and help.
Old 09-07-2020, 07:57 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Bounus pic!
I will fix ASAP.
Nice mod! Are those the Nankang NS2 tires? If so, how do you like them.
You know that you can direct link your pics here so people don't have to click on the link, right?
Old 09-09-2020, 01:30 PM   #3
Pinchlite
Yes.
Like these way,way better then the nitto neogens,and a bit better then pilot sports.
These ride smoother/softer even though they are smaller sidwall(45),and minor stretched compared to my others that were 50 sidewall.
The nittos seem like trash after riding on these.
The nittos are hockey puckish even in very warm weather.
Hands down a real nice tire...so far mind you.
I paid 360 CAD all in delivered to door.
Old 09-09-2020, 10:35 AM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Rolling fenders is fairly popular here in SoCal given the number of stance cars.
Unrelated side note, I've always liked the roof rack look.
On Instagram
On Wheelwell
Old 09-09-2020, 01:35 PM   #5
Pinchlite
fenders
My fenders are shaved instead of rolled.
That bolt trick I discovered did wonders.
No need to pull fenders.
I want to pull the rears though as they are shaved aswell
I do get rub highspeed dips.
I may try and pull out with fender roller(I own one)
Repainting and bodywork is no issue for me if need be.
Got a few compliments on the roofrack aswell.Its perfect for small kayak.
Need front wheel alignment specs Rob888 DIY / Maintenance / Service 1 03-05-2020 03:53 PM
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
wtb silver yaris sedan FRONT driver door and front drvr fender Slitwrist Smile Willing to Buy by private party 2 04-01-2011 08:59 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Right front fender bender.. where to buy it new? Lafiro DIY / Maintenance / Service 4 06-15-2009 09:57 AM
