Old 11-25-2023, 05:21 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
DIY Rear lower sway bar for mk2
heya guys, so i realize the rear lower sway bar by most comapnies is just two drilled plates and a piece of bar.
We can make this with some 2mm steel plate and some 30-40mm steel square bar.
Now you could weld this but you can easily bolt this together too if you only have a drill.
Here is the megan racing brace I will copy, the amount of bolts they are using is overkill, some brace us two but I figured 3 would traigulated would be enough each side. this allows you to use a piece of 2mm x50mm sheets or even cut large steel square bar like i have.
Here is my started brackets, 3 bolts each side and enough room to weld the square bar on the end.
Tomorrow will mig weld it up, paint it and post finished product before taking the car for a good test drive.
Compeer is offline   Reply With Quote
Old 11-27-2023, 06:48 AM   #2
Compeer
Decided on a more inturned "D" shaped bar and down sized the cross member part to 20mm square tube after studying the trd bar and watching a bunch of stuff on building sway bars.
Gave it a few coats of Zinc black paint
And then got it mounted on the car, bit hard to see but it fits perfectly and feels very solid.
The back end already feels beter, haven't taken it for a real good drive, but just around town after making it , the back end felt nicer, like I was not being forced to hold myself on myset quite so much, cant wait to add the new front strut bar i got and put the tien flex z back on. Also may add some extra little bolt on ears that join the lower shock mount to the spring seat as well, didnt want them on this bar as it would have been a night to get on and off (already is tricky).
Old 02-14-2024, 11:35 AM   #3
RedRide
RedRide's Avatar
I have an '09 Yaris. bought new in '09
Years ago I installed an after market rear "sway bar."
It improved its handling quite noticeably and I recommend it
With its solid rear axle you would not think it would but it really does..
Old 06-25-2024, 09:59 AM   #4
KermitAUS
Drives: Yaris 2009
Great idea.
KermitAUS is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Rear Sway bar, worth it ? Other options? road_junky Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-06-2014 10:08 AM
WTB: Weapon R Dragon Intake and TRD rear sway bar. TerenceCruz Willing to Buy by private party 2 07-28-2013 05:13 PM
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
