Old 01-23-2014, 09:25 AM   #1
road_junky
Drives: 2007 Yaris sedan
Rear Sway bar, worth it ? Other options?
I am driving a 2007 base Yaris sedan. Biggest complain is wind sailling at highway speed. I will do a lot more of this type of driving soon and cannot stand the car as it is right now. Living in Canada with some heavy bad winter conditions, lowering is not an option I want to go. I also don't want to put big money on trying to change driving dynamic. Would adding a rear sway bar help fix this big time or not that much. I'd consider changing the car if there is no easy fix with sway bar and tires, I need a new 4 seasons set anyway in the coming months.
Would like to see what you experienced before spending money on this one.
Thanks for your help!
road_junky is offline   Reply With Quote
Old 01-23-2014, 09:40 AM   #2
I realize you a new (welcome) but this is probably one of the most discussed items on here. Rates right up there with 'will I rub with this wheel/tire setup?'.
Simply put, yes it is worth it.
Old 01-23-2014, 11:06 AM   #3
A sway bar is the best mod you can do on the Yaris for the money, period. It's one of those things they should have put on the car from the factory. Reduced body roll, reduced wind buffeting, and enhance cornering performance really help this car.
Here's a link to the Whiteline bar, my preferred brand. It's adjustable with two settings, and very easy to install.
Happy to ship to Canada, by the way.
http://shop.microimageonline.com/Whi...-xD-BTR86Z.htm
Old 01-23-2014, 04:58 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
In an effort to reduce highway wander our cars suffer from, I experimented using the TRD sway bar and numerous tyre tread patterns. While the car certainly felt more stable with the sway bar and handling was indeed much improved, I discovered that tread pattern has the most significant effect on highway wander. I have completely eliminated highway wander on my car without the sway bar installed.
Old 01-23-2014, 05:24 PM   #5
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
The rear sway bar is a must! As others have stated, it does help with wind sailing and roll. I did a before/after swaybar on a roundabout going 40-45 mph - it greatly reduced body roll (I don't do that on a daily basis obviously). I drive to California often and on the way there, there's usually winds reaching 30-40mph. My friend drove my car back up both with/without the sway bar and noticed the difference without me saying a word about installing it.
MyzticZ3r0 is offline   Reply With Quote
Old 01-24-2014, 10:20 AM   #6
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I, too, recommend installing a rear sway bar!
Mittelklasse is offline   Reply With Quote
Old 01-25-2014, 12:34 AM   #7
ohms
Drives: 07 yaris 3door
so...what tires?
ohms is offline   Reply With Quote
Old 01-25-2014, 01:06 AM   #8
kimona
kimona's Avatar
Originally Posted by ohms View Post
so...what tires?
Look for these characteristics:
1. non-aggressive tread pattern
2. flat, wide, continuous center band
3. silica-based tread compound
Old 01-25-2014, 02:38 AM   #9
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Indeed, I discovered this also. I had kumho kh 18 up front but due to getting a
flat the dude at the tyre shop offered me hankooks with different tread patterns. I noticed on highways the car wanders sometimes specially with high winds.
Old 02-05-2014, 08:24 PM   #10
Rednaz
Drives: 2006 Yaris 1300
@cali yaris: I sent an email to you on the 14th of Jan,and haven't received a reply yet? I'm based in South Africa and need one aswell. Do you do shipping to RSA?
Rednaz is offline   Reply With Quote
Old 02-05-2014, 09:23 PM   #11
I just PMed you, hope you can reply soon
Old 02-06-2014, 10:08 AM   #12
Rednaz
Garm, check your emails please. Thanks
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
Rear sway bar snow clearance? CrankyOldMan Performance Modifications 19 09-15-2011 01:40 AM
Rear Sway Bar? SimTronik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 10-07-2010 04:13 AM
rear anti sway bar = better mileage? Lewis Fuel Economy Forum 42 12-04-2009 10:42 AM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
