Old 07-06-2007, 07:15 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Offsets
Okay, so I'm looking into buying a Yaris liftback. I've got a set of 16x7 wheels with a +35 offset. I plan on lowering, too. Will this rub?
Are there any guidelines as far as wheel offests go for the Yaris? I thought I read you want something greater than +38. Any truth to this?
Old 07-06-2007, 07:19 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Congrats on deciding to purchase a Yaris! I have to ask, did my appearance at the June 2nd Scion cruise help in the deciding factor? Sorry though about offset, not sure what and what isn't ok.
Old 07-06-2007, 07:55 PM   #3
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
+40 or more is your best bet, how low do you want to go?
what tires are you wanting to run?
probably with 195/40/16 you wo'nt have any worries but then again +35 is going to poke abit and this has been a topic of discussion in recent days
nothing wrong with a little rubbing, you can always roll your fenders too and maybe some neg. camber
SPONSORED BY
Old 07-07-2007, 01:11 AM   #4
Thirty-Nine
Well, I haven't decided 100% yet, but it may happen! Your Yaris really did look good, and I have liked them for quite a while. We'll see.
How low? Probably about 2". I'd probably run a 205/50/16 to keep the speedo correct. I don't want to roll the fenders or do neg camber. So, I'll look for +40 wheels when the time comes.
Old 07-07-2007, 02:04 AM   #5
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
I'm running 40 offset on 15" wheels and 205-50's on about a 2.5" drop and I get light rubbing under severe driving conditions. for a 16" or 17" wheel, i would suggest an even milder offset, closer to mid-40's depending on the tire profile.
reznunt is offline   Reply With Quote
Old 07-07-2007, 02:10 AM   #6
brickhardmeat
Lonesome Cowboy
agreed and this is why with the same set up as yours I think I'll end up with some camber bolts and go neg. camber
I'll consider rolling my fenders too but I don't think it is crucial with 205/50/15, I'm not too worried about minor rub
SPONSORED BY
Old 07-07-2007, 09:02 AM   #7
brickhardmeat
Lonesome Cowboy
have you thought about adding camber bolts, someone was talking about doing this and I think it may work since them rubbing is on the outer, I actually think visually neg. camber looks cool, I'm still doing some research
SPONSORED BY
Old 07-09-2007, 02:23 PM   #8
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
since it's not a track car, the really minor rubbing on the splash guards isn't a problem for me. i've had this type of rubbing, and alot worse, in many different cars so i'm used to it. if i wanted to put her on the track, i'd raise up the height and/or remove the splash guards anyway. i'd have to say no to the camber bolts to try and save as much tire as i can. but they would definitely work for you.
Old 07-07-2007, 02:11 AM   #9
brickhardmeat
Lonesome Cowboy
talk to largeandinfront
SPONSORED BY
Old 07-07-2007, 02:33 AM   #10
Thirty-Nine
Hmmm ... I did a search for that username and nothing came up ...
Old 07-07-2007, 07:58 AM   #11
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im also looking into 16's with a big offset but i need someone to tell me exactly what i need to get....
Old 07-07-2007, 08:59 AM   #12
brickhardmeat
Lonesome Cowboy
sorry about that, largeorangefront is his user name, I butchered that one and I don't think that was the first time I called him that, ha ha
if you roll and pull these fenders you will be fine, it's up to you if you want to do that much modifying or just go with a safer offset really
SPONSORED BY
Old 07-08-2007, 02:01 AM   #13
Thirty-Nine
After doing some more research, it appears the OEM offset is +45, so I can see why my 16" rimd with +35 on 205/50/16 would rub. However, a 16x7 +45 would probably be okay with a 205/50/16, right or would I still have rubbing issues?
Old 07-08-2007, 03:17 AM   #14
brickhardmeat
Lonesome Cowboy
with a full 2 inch drop you may have some rubbing but I think you should be pretty much ok, best if you went say 195/45/16 or so, talk to some guys with lowered cars on 16 wheels, I believe largeorangefront is 1.7 drop with
+40 and 205/50/16 and walter was running 16's with little sidewall and more than a two inch drop
SPONSORED BY
Old 07-08-2007, 07:33 AM   #15
kimona
kimona's Avatar
Drives: 2014 White VITZ
This is the info I have about OEM rim and tire sizes:
OEM 15x5.5, ET45, 185/60/15
OEM 16x6, ET51, 195/50/16
OEM 17x6.5, ET51, 205/45/17
Old 07-10-2007, 05:39 PM   #16
ya_RS
ya_RS's Avatar
Drives: 07 RS
OEM 15x5.5, ET45, 185/60/15 or +38
I also assume that these are in stock height? now will lowering with the TRD springs 30 mm front and 30mm rear effect this?
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 07-10-2007, 06:37 PM   #17
brickhardmeat
Lonesome Cowboy
most aftermarket wheels are going to be 7 inches wide and that changes things a bit even with the same offset, also tire width and profile and how low you go, all things would have to factored in, I think lowering on TRD springs with any offset within reason should be fine up to a 16 inch wheel, you are still going to have quite a gap there
SPONSORED BY
Old 07-08-2007, 11:59 AM   #18
Thirty-Nine
Awesome -- thanks!
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
Yeah, I know... I'm a sellout. ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 53 06-21-2007 12:29 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
Offsets? Yarisagos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-12-2007 08:06 AM
Wheel Offsets bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-08-2007 01:55 AM
