Old 09-08-2007, 07:45 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Who has installed Megan Coilovers?
Okay, I bought the Megan coilovers.
Who has installed them? Is there really any drilling that needs to be done (as in Vanderkitten's write up)? He's the only person I've heard talk about installing these coilovers.
Does anyone have pics of the adjusters installed?
(I have installed aftermarket suspension setups before, so the actual installation doesn't bother me at all.)
Old 09-08-2007, 09:17 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
colinT and vanderkitten is all I know of
SPONSORED BY
Old 09-11-2007, 08:12 PM   #3
WeSellCarParts
Drives: All Brands
Send a message via AIM to WeSellCarParts
Ive sold 4-5 sets but a couple of them were really recent so not sure if they have installed yet
WeSellCarParts is offline   Reply With Quote
Old 09-23-2007, 04:40 PM   #4
Thirty-Nine
So, I'm installing these right now. I've run into a problem with the rears, though. It's like there needs to be a spacer somewhere on the shock piston, as they're too long. I've run out of thread on the bolts, and there's still about 1.5 inches to go (of bare shock piston).
Do I need to use the black OEM dust cover? Did people have to use this on their Teins?
Old 09-23-2007, 04:44 PM   #5
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Yeah. For my teins I left all stock parts but the springs themselves.
I just re-read what you posted... I'm not clear what bolt you're talking about. There should only be one. Unless you took the strut off. ????
Old 09-23-2007, 05:56 PM   #6
Thirty-Nine
Yes, I'm replacing the shocks/struts AND springs (they're full coilovers).
I got the backs; I used the OEM dust cover/bumpstop. I didn't use the bumpstop Megan supplied, as I think it'd limit the travel if I'm using the OEM.
Now I'm working on the fronts. I can get everything so far, but am having a problem removing the hard rubber dust covers on the tops of the struts (in the engine bay) of all things! I've gotten everything else undone. :-D
Any tricks to getting the stupid dust cover off? I assume it's just a flathead screwdriver wedged underneath and twist to pop it off ...
Old 09-23-2007, 06:04 PM   #7
staticorex
staticorex's Avatar
The cover comes right off. Make sure you aren't pulling off the whole thing. Just the cap. The black rubber thing is two parts.
Old 09-23-2007, 06:27 PM   #8
Thirty-Nine
I've gotten two flathead screwdrivers underneath the darn thing, and I can't get either one of them to come off ...
EDIT: Nevermind - I got it. Thanks for the pointer!
Old 09-23-2007, 06:29 PM   #9
staticorex
staticorex's Avatar
It sounds like you're trying to pry off the whole piece. There is a small thin cap on the whole rubber cap. It pulls off with no effort. I wish I could explain it better. :/
Pic # 15.
http://www.yarisworld.com/forums/sho...ht=diy+springs
Edit: Yay. :)
Old 09-23-2007, 08:10 PM   #10
Thirty-Nine
Well, it looks like I have to throw in the towel for the night. I don't have the right 17mm wrench to get the nut off of the front struts. I assume most people used a 17mm offset wrench with a 6mm allen wrench in the top?
Old 09-23-2007, 10:41 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
I used an air gun, but the offset wrench is how most do it.
On the rear I needed to use a spacer also, the shock was too tall and ran out of threads, I just used a bunch of washers.
Old 09-23-2007, 11:15 PM   #12
dsc_pat
track or die
Drives: Yaris LB CE CDM
what are the spring rates on your cusco set up ?
thanks
dsc_pat is offline   Reply With Quote
Old 09-24-2007, 12:03 AM   #13
Thirty-Nine
I'm going to pick up the wrench and 6mm allen tomorrow so I can get it done!
Old 09-24-2007, 12:13 AM   #14
03Z33
03Z33's Avatar
Drives: TCR10
thanks
I'm running SK's not Cuscos. They're 8K front and 5K rear.
Cool, post up if any questions
Old 09-25-2007, 12:00 AM   #15
dsc_pat
track or die
thanks
does it rub on your pic ? ;)
Old 09-24-2007, 01:28 AM   #16
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yea that is what I did.
Old 09-24-2007, 10:01 AM   #17
Thirty-Nine
Just a big thanks to everyone that's helped already! For not being a huge forum, there are a lot of helpful people – and they happen to be quick to respond, too! You guys are great!
Old 09-24-2007, 10:02 AM   #18
staticorex
staticorex's Avatar
:) You got them on?
Megan Springs? churp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 06-06-2007 03:11 PM
Megan or Tein suspension elmercurrie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 43 05-31-2007 09:41 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
cusco coilovers installed badhabitz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 02-03-2007 04:43 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
