Old 07-16-2007, 04:48 AM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
Check Engine Light Question
So my check engine light came on, check the milage and figured it was time to change the oil. So I did and now the check engine light still blinks 6 or 7 times before turning off. Just wondering if anyone knows that means? Thanks
falkor_99 is offline   Reply With Quote
Old 07-16-2007, 05:40 AM   #2
Nigal
Nigal's Avatar
Is it when you first start the car? I've always heard that 9 times out of 10 when the light comes on it's a problem with the gas cap not being tight.
Old 07-16-2007, 06:21 AM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
You have to reset the light after you change the oil. Its not automatic.
Old 07-16-2007, 08:10 AM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Is it a check engine light or does it say main req? The sedans have a maintenance required light that comes on, but I am not for sure about the hatch. Might wanna check with some hatch owners. It might be a real check engine light and something might be wrong.
Old 07-16-2007, 04:45 PM   #5
Thotprawsis
Drives: '07 Blazin' Blue LB
If it's the service light, try this:
Push and hold the odometer reset button
Turn the key to the “on” position
The service light should start out solid, start blinking for a couple of seconds, go solid again for about one second and then go out.
Then turn the ignition off
This should reset the service light. According to a thread on toyotanation.
I hope this helps
Thotprawsis is offline   Reply With Quote
Old 07-16-2007, 04:47 PM   #6
Thotprawsis
Even better yet. Stop by the dealership, to be on the safe side!
Old 07-16-2007, 05:21 PM   #7
slvryaris
slvryaris's Avatar
It is in the manual for how to reset the maintenance required light, but make sure its not a check engine light.
Old 07-16-2007, 11:14 PM   #8
falkor_99
falkor_99's Avatar
I hope this helps
You totally rock man....did exactly what you did and its as good as new.....thank you sooo much dude
Old 07-22-2007, 07:12 AM   #9
r300f28
Just did my first oil change yesterday on my 07 Yaris sedan.
Amsoil SAE 5-30 and Amsoil filter. Did not have to reset anything, no blinking lights, NADA. Have started the car several times since. Was aware of the problem of the reset after an oil change & had the information on how to do the reset. Turns out didn't have to do anything
r300f28 is offline   Reply With Quote
Old 07-22-2007, 08:06 AM   #10
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
It doesn't come on until 5000miles I always reset mine when I change the oil that way I know when it comes on I need to change my oil
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 07-22-2007, 10:10 AM   #11
slvryaris
slvryaris's Avatar
It is programmed for 5,000 miles after it is reset. If its not coming on then you need to take it back to the dealer, but I believe that every one of them has a main. req. light.
Old 07-22-2007, 05:15 PM   #12
swng
swng's Avatar
Drives: 06 3-dr auto RS
I have just come across a useful article on this subject:
http://www.extragasmileage.com/is-yo...ve-to/#more-85
swng is offline   Reply With Quote
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 08:16 AM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Engine Question? N.Y.YARIS Performance Modifications 8 04-03-2007 10:08 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
