Old 07-16-2007, 04:45 PM   #5
Thotprawsis
Drives: '07 Blazin' Blue LB
If it's the service light, try this:
Push and hold the odometer reset button
Turn the key to the “on” position
The service light should start out solid, start blinking for a couple of seconds, go solid again for about one second and then go out.
Then turn the ignition off
This should reset the service light. According to a thread on toyotanation.
I hope this helps
Thotprawsis is offline   Reply With Quote
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 08:16 AM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Engine Question? N.Y.YARIS Performance Modifications 8 04-03-2007 10:08 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
