Old 08-20-2007, 05:56 PM   #1
NimbleYarisOwner
Yaris my baby
Drives: Yaris Hatchback 2007
Daytime Lights
Hello Everyone,
Being cheap, I want to improve fuel economy by eliminating the daytime
running headlights.
They are dangerous for me because at night I think i have
my headlights on when really its only the daytime running headlights.
So there is no rear lights at all.
Has anybody done that?
Thanks!
NimbleYarisOwner is offline   Reply With Quote
Old 08-20-2007, 05:59 PM   #2
nqd
Drives: 07 Yaris LB Absolute RED
hey welcome to the boards....
a bunch of us have already done this...
here is a link to how
http://www.yarisworld.com/forums/sho...ht=disable+drl
v
nqd is offline   Reply With Quote
Old 08-20-2007, 06:15 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by CheapYarisOwner View Post
Hello Everyone,
running headlights.
I can't imagine you'd bet much better milage because your lights aren't on. Please correct me if I'm wrong, though.
Old 08-20-2007, 06:22 PM   #4
Edd
Drives: None
True, it shouldn't be significant unless you've got exceptionally high wattage DRLs.
Edd is offline   Reply With Quote
Old 08-20-2007, 10:24 PM   #5
alhope34
Spool'd
Drives: 07 yaris, 16 gen coupe rspec
No, I haven't, not once in my life. I always remember to turn the lights on at night.
alhope34 is offline   Reply With Quote
Old 08-20-2007, 10:33 PM   #6
churp
Clean and (dis)Functional
churp's Avatar
Just remember the other lights (heater/ventilation/etc.), if they're not on your tailights aren't on either!!!
____________
Old School Cobble Jockey
Old 08-21-2007, 09:10 AM   #7
NimbleYarisOwner
Yaris my baby
Currently I average about 34-35 mpg.
I will see what the impact is of not having DRL's.
There must be a MPG impact because you can't get free energy as fas as i know.
I still think they are dangerous because they are too bright and I recieved a ticket.
Old 08-21-2007, 10:52 AM   #8
Thirty-Nine
You received at ticket for your DRLs? I hope you faught that.
Old 08-21-2007, 10:59 AM   #9
Black Yaris
der Zeck
Black Yaris's Avatar
noobs......
Old 08-21-2007, 01:16 PM   #10
BailOut
Steals terrorist's lunch
BailOut's Avatar
You're not going to notice any FE improvement without DRLs as the gain will be microscopic.
Our headlights run at 60W in DRL mode, and 55W in "night mode". 60W * 2 headlights = 120W.
12V * nA =120W
n = 10A
Our alternator is rated at 60A, and "idles" around 20A, so the DRL are using half of the idle load. The stock stereo uses another couple of amps, and so does the ventilation fan.
In other words you can have the DRL, the fan on setting 2 or 3, the stock stereo on at mid-volume and have a map light going without the alternator placing any additional load on the engine. However, if you have a large after-market audio setup, or if you drive like a maniac and place a lot of load on the engine, you have much less of the alternator's idle output to play with, if any.
- Brian
Share the Road
Old 08-21-2007, 02:05 PM   #11
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
yay for bailout! always got the answer when it pertains to fuel economy. i'd only get rid of DRL because they're so bright.
Don't Milk the Cat!
-Said by me during a game of Cranium.
sherryberry is offline   Reply With Quote
Old 08-21-2007, 04:51 PM   #12
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Wait, the headlights draw more power during the day? I've always heard of it operating the other way around, with the DRLs running with reduced output.
bearda is offline   Reply With Quote
Old 08-21-2007, 05:19 PM   #13
BailOut
BailOut's Avatar
Well, bearda, we're both wrong. After looking at the wiring and lighting diagrams again I see that both DRL and regular headlight usage are 55W while the brights are 60W.
This is actually good news as it means the DRL use 10W less than I originally calculated, meaning around a 9A load on the alternator rather than a 10A load.
- Brian
Share the Road
Old 08-22-2007, 03:55 AM   #14
adamschneider
adamschneider's Avatar
Drives: Bayou Blue 2dr, AT
Seems to me that if the front headlights are running at the same wattage in "day" or "night" mode (which is absolutely freakin' bizarre!), you're still using a little more power at night because of all the other lights (tail lights, running lights, etc.), correct?
I thought I noticed, by the way, that in "night" mode some other little bulb lit up in there...
adamschneider is offline   Reply With Quote
Old 08-22-2007, 10:00 AM   #15
NimbleYarisOwner
Yaris my baby
OK so 55W*2=110 watts
with ~30% engine efficiency thats 366 watts or approx. 1/2 hp.
from there you can figure out your gas quantity to make that power.
Old 08-22-2007, 10:07 AM   #16
BailOut
BailOut's Avatar
I thought the same thing but discovered it's just the running/position light nearest the headlight lamp that adds to the lighting effect.
- Brian
Share the Road
Old 08-22-2007, 10:16 AM   #17
BailOut
BailOut's Avatar
The engine's efficiency doesn't apply here as the alternator is capable of producing 20A while in its "idle" state. The only way you could make the alternator drag less would be to remove it from the vehicle. The 30% rule would only come in if you are drawing more than that 20A.
20A * 12V = 240W, so you have 240W to play with before the alternator clutches and really starts creating drag.
- Brian
Share the Road
Old 08-24-2007, 09:07 AM   #18
bearda
bearda's Avatar
So it's 1/2 hp in the worst case, when the rest of the devices on the vehicle are collectively pulling 20A or more and the alternator is going to drag down an additional amount based on the DRL draw, right?
So you're looking at about around a .5 % increase in efficiency if you;'re constantly dragging down the alternator. Keep the DRL, the extra visibility is worth it.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 11:37 AM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
