Old 08-21-2007, 01:16 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
You're not going to notice any FE improvement without DRLs as the gain will be microscopic.
Our headlights run at 60W in DRL mode, and 55W in "night mode". 60W * 2 headlights = 120W.
12V * nA =120W
n = 10A
Our alternator is rated at 60A, and "idles" around 20A, so the DRL are using half of the idle load. The stock stereo uses another couple of amps, and so does the ventilation fan.
In other words you can have the DRL, the fan on setting 2 or 3, the stock stereo on at mid-volume and have a map light going without the alternator placing any additional load on the engine. However, if you have a large after-market audio setup, or if you drive like a maniac and place a lot of load on the engine, you have much less of the alternator's idle output to play with, if any.
- Brian
Share the Road
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 11:37 AM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
