Old 11-25-2008, 07:44 AM   #73
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
second car?
Its a Chao!!!
Old 12-01-2008, 02:27 PM   #74
anubisx99
here again..
anubisx99's Avatar
Drives: 2008 toyota yaris LB
Originally Posted by PHXDEMON View Post
Don't be threating me with a good time!!!
anubisx99 is offline   Reply With Quote
Old 12-01-2008, 02:28 PM   #75
anubisx99
here again..
anubisx99's Avatar
updates? geez
Old 12-03-2008, 04:55 AM   #76
9vapors
Awesome.
9vapors's Avatar
Drives: 07 Meteorite Metallic Hatch
Im here for the turbo kit!
9vapors is offline   Reply With Quote
Old 12-03-2008, 09:57 AM   #77
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
would you like to supersize that order for $0.59 more?
Wanted: Forced Induction
Old 12-04-2008, 01:13 PM   #78
it's amazing how creative you get when you want to keep a thread alive.
Old 12-04-2008, 03:28 PM   #79
treppen
Drives: BRUTAL
^lol i know iv been watching since 1988... at least thats how it feels
I ride like I got a horse stable under my hood
treppen is offline   Reply With Quote
Old 12-04-2008, 03:38 PM   #80
at3GG
at3GG's Avatar
Drives: 07 metmet LB
ok NOOB question. With the IC piping going directly to the intake, where does the initial air for the engine come from? Is there simply enough "stuck" in the intercool to be sucked in to fire the engine? Or is it just that when the spark ignites the fuel...explosion..pulls in more o2?
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-04-2008, 05:29 PM   #81
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
gboezio is offline   Reply With Quote
Old 12-04-2008, 05:42 PM   #82
the "air in" part is where some tubing and your air filter goes, just for clarity.
Old 12-04-2008, 06:11 PM   #83
Tamago
Tamago's Avatar
Drives: UZJ100
for some reason this made me LOL.. thanks, Captain Obvious
Old 12-04-2008, 06:13 PM   #84
Tamago
Tamago's Avatar
Drives: UZJ100
i think someone has hit "THE WALL"
Old 12-04-2008, 08:15 PM   #85
at3GG
at3GG's Avatar
ahhhhh ok sorry for the dumb question
Tanabe Df210's
Old 12-04-2008, 08:33 PM   #86
at3GG
at3GG's Avatar
so wait...his intake assembly is going to be behind the engine then?
Tanabe Df210's
Old 12-06-2008, 09:42 AM   #87
gboezio
gboezio's Avatar
I guess, the turbo need to be very close in the exhaust piping, just above the oil level for oil drainback, so the air intake need to bring fresh unrestricted air there, pressurized and sent out front for cooling, back to the throttle body.
As far as fuel management, I just don't see how not to upset the computer, piggyback is a hell of a headache and not cheap, the adaptation of the ECU will mess the tune in a matter of hours, it need a complete reflash, or to run a standalone in conjunction with the present computer to run the acceesories, but the EMS will still be pissed off...
The only ways I see to do this from now is either to run a 5000 $ Motec EMS or revert to cable throttle, hacksawing the whole throttle system and revert to pre historic engine control.
To run a piggyback:
EGO :
we need to lie to the EMS, we need to control, O2 sensors signal so the ECU thinks that it's running right not detecting the over rich condition or it will trim the fuel gradually until maxed out, then will trigger limp mode
MAF :
Limit the MAF signal so the EMS don't detect overboost and trigger limp home maps, the ECU need to think he's running WOT
Relying on a MAF signal mod will mess the timing tables, so the engine need to run as stock below 0 PSI
Injectors :
Intercept the injector signal modifying it to run larger injectors, the piggyback need to read Manifold pressure and compute pulse width
Ignition :
Intercept the CPS signal and offset the signal as boost retard (6 PSI+), still the engine may see that the crank is not phased with the cams sensors and trigger a CEL and limp mode, if below 6 PSI leave timing in full advance, use higher octane fuels instead.
I'm sure that if I think of it some more I will find even more stuff and the ECU will fight back any abnormalities, it may even datalog and blow the warranty, if someone care :D
Edit : I told you I'll find something else lol, the EMS may be able to compute that the TPS and MAF signal are out of wack and trigger limp mode again.
Testing testing testing...
Old 12-06-2008, 11:13 AM   #88
heeroyuy01195
Post count means nothing.
And sometimes fury woodland creatures, birds, etc. lol
But I've only seen that happen on all out racecars that just happen to suck in an animal while on the track....Actually one of the Ferrari F1 cars got taken out of a race because a bird got sucked into the engine...poor little guy :(
So no updates?
Old 12-06-2008, 12:49 PM   #89
poor little guy :(
The driver? LOL
Old 12-06-2008, 11:53 PM   #90
heeroyuy01195
The driver? LOL
I'll leave that for you guys to decide
Under $2500 Tubo Kit Update 2 cdydjded Forced Induction Forum 72 11-02-2008 09:44 PM
$2500 Turbo Kit is back to life! bdc87 Forced Induction Forum 8 10-20-2008 09:46 AM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
