Old 09-03-2007, 10:04 AM   #1
cdydjded
Drives: Yaris LB Turbo
Under $2500 Tubo Kit Update 2
Well I spent all weekend figuring out the wiring for the AEM FIC. Not that it takes that long to install but I was trying to find the easiest way to install it. I found the injector, cam sensor, crank sensor, switch power & ground. I still need the TPS signal & O2 signal. If anyone can help I would apriciate it. The manifold is done, turbo & I/C is on the way & the oil pan is getting modified for the oil return. Any questions please ask.
cdydjded is offline   Reply With Quote
Old 09-03-2007, 10:56 AM   #2
Tapper
Tapper's Avatar
Drives: 2008 Black RS 2dr
Cool stuff! What injectors are you using?
Tapper is offline   Reply With Quote
Old 09-03-2007, 11:37 AM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
can you take a closer pic of the welds?
i'll see if i can find the signals you need on etimago's repair manual.
Old 09-03-2007, 09:06 PM   #4
can you put an additional o2 bung on the downpipe, so it has a dedicated sensor?
Old 09-04-2007, 08:52 AM   #5
cdydjded
Since it will be only a 5-7lb kit I am going to try the stock injectors, if they are not sufficiant I will use TC injectors
Old 09-04-2007, 08:54 AM   #6
cdydjded
Give me till tonight for the close ups. Great if you can find the signals for me. I a m trying also to cross reference a XB install I found on a AEM forums.
Old 09-04-2007, 08:59 AM   #7
cdydjded
All ready planned. This kit will not remove the front O2 like the ZPI kit.
Old 09-04-2007, 11:52 AM   #8
joey1320
joey1320's Avatar
Drives: Yaris LB
hey if you go tot he repair manual on the "diy" section you will get the "Engine Cotrol System". click on that and then go to page 31. there you can find the pinouts for the ecu and if go to the next 2 pages you will get all the info needed. good luck!
Old 09-04-2007, 02:00 PM   #9
cdydjded
Thats exactly what I needed. You get a discount on the kit if you buy one!
Old 09-04-2007, 03:44 PM   #10
joey1320
joey1320's Avatar
Drives: Yaris LB
haha thanks man but i'm making my own
Old 09-04-2007, 03:45 PM   #11
ChinoCharles
Drives: LB
Joey, want to come down to Bedford at 6?
Old 09-04-2007, 04:46 PM   #12
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
I wanna see how this goes...
Watching...
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline   Reply With Quote
Old 09-04-2007, 04:48 PM   #13
forpinks
forpinks's Avatar
Don't forget to powder coat the log manifold in Sterling Silver!
Old 09-04-2007, 04:49 PM   #14
cdydjded
What are you going to use for engine managment?
Old 09-04-2007, 05:20 PM   #15
joey1320
joey1320's Avatar
Drives: Yaris LB
as of right now i got the the emanage. i'll see how that works and go from there. i gotta finish everyhting and schedule the dyno time.
what are your hp goals with the setup?
Old 09-16-2007, 10:37 PM   #16
YogiYaris
Drives: Blue 2007 Toyota Yaris
Doesn't greddy make a kit for something like 2k that is bolt on with no FMIC for the 1nz?
YogiYaris is offline   Reply With Quote
Old 09-17-2007, 12:08 AM   #17
for the xb, not the Yaris -- different ECU and some other mods needed I believe
Old 09-17-2007, 08:57 AM   #18
joey1320
joey1320's Avatar
Drives: Yaris LB
and greddy's kit is a supercharger kit not a turbo.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
