#73 |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I was thinking about this oil cooler branded Flex-a-lite and includes a dual circuit and a remote fan triggered within a certain temprature threshold.
http://www.flex-a-lite.com/auto/html/remote-mount.html Oil cooler 45901 |
#74 |
that's pretty fancy! -- is your oil too hot?
#75 |
#76 |
Unless there is a leak, your oil pressure should be exactly the same.
#77 |
it depends on what part of the circuit he taps into for the cooler.
#78 |
#79 |
you're going to cool the transmission gear oil? why?
#80 |
i think flex-a-lite is a very good brand as well, its a good choice parmas.
since it comes with a fan controller, you could skip installing an external controller like what i did. am using a pivot super temp here. just curious, wouldn't you rather have a dedicated cooler for each engine oil and transmission?
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#81 | |
Re: ceramic coating... I done some research and there are many that say is a good asset to own heat management. Here is quite difficult to find someone to do the job for you and I don't wish to risk sending all the parts abroad and never come back! Although I really wish this coating I will keep you updated if I could find one somewhere... |
#82 |
so how are you going to pump the transmission gear oil through the cooler?
and "keeping the oil as cool as possible" is not smart. oils are designed to operate in a specific temperature range for them to be efficient. over-cool your transmission gear oil (not sure how you're going to pump it) and you'll end up with oil that just doesn't laugh, as you are heat cycling the oil constantly. leave the transmission alone, focus on the engine oil. if you want to keep oil pressures constant, i suggest cooling the oil coming OUT of the turbo (provided there is NO backpressure through the cooler).
#83 |
just to clarify, we're talking about manual transmission here and not automatic right?
#84 | |
Still trying to find someone who can do ceramic coating ..... |
#85 |
just be careful to not pressurize the return flow to the oil pan. seriously oversize those lines, as you will blow your turbo seals if there's any backpressure on the oil return line.
#86 |
#87 | |
#88 |
if the cooler is between turbo outlet and oil pan, oversize will not affect oil pressure.
it is highly UNrecommended to restrict oil coming back from the turbo, so if you do this, size it for 3times more than flow out of the turbo.
#89 |
Carless in Chicago
I hate to add a pointless post to this great thread, but I need to subscribe.
Congrats on the progress Parmas and best of luck with the rest of it.
Wanted: Forced Induction Some say that he is the secret love child of Ferrari and Porsche, and others say that he would lap James May twice in a 1/4 mile drag race. All we know is that he is called The Stig. |
#90 |
I want to see this car on the road soon. Please.
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
