toyota
would 16x8 with +25 offset fit on the rear?
would 16x8 with +25 offset fit on the rear without rubbing when car is full?
what tire?
i'm wagering NO, not without some camber added or some fenders pulled.
![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
NO!!
I have 16x7 +42 offset all around, 15mm spacer on rear, stock camber on rear, front should be like 0.5 more than stock. I already rub the front in full turn ![]() I rub the rear in some small bump, even with no passenger!! I've try e passenger with me at the same time, super rub even on local... I think you have to run a large camber..if you want to run 16x8.... but still need to see how low you are
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
toyota
thanks...so 16x7 +40 on the rear its safe to put 10mm spacers to get zero rub even when full but i may be runnign 195 on the tires. assuming u got 205s
yes, an effective +30 and a 195 tire you'll be fine with a X7 width
I'll rub the front a little bit, when I push it hard in some corner, but you should be fine if you run some 195 tires
toyota
im thinking of staggered set up front 16x7 +40 offset and then rear 16x8 +25 offset car is in trd spring but may switch to df210 later on. plus camping month the car get full so i dont want rubbing on the fenders..
Apexing Egg!!
i have 15x7 +25, no rub. i could actuall use a spacer in the rear (i have some camber too)
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#9 | |
BTW - this is your 3rd 'rub' thread isn't it?
here is some pic of mine, 16x7 +42, 15mm spacer in the rear
if you run 16x8 +25...you should be (0.5"+2mm) more flush than mine at the rear..... i think you should be rub when your car get full..... (with the stock camber)
#11 | |
![]() he just don't want to get rub
#12 | |
toyota
but the way the rubbing issue is on the side of the fender..so trd or df210 should not make a difference if u got the right offset and tire size.. 2 person on the back on the trds tucks the tire on the fender..just like that. Last edited by marcus; 06-23-2009 at 06:31 PM. |
i'm not lowered by spring, so may be yours are little bit higher than mine, but softer....
#14 |
toyota
i find trd / eibach pro kit i believe really soft..which maybe a good thing most of the time.
#15 |
![]() ![]() Drives: 07 yaris hatch Join Date: Jul 2009
I'm interested as I'm putting 16x8 on rear of my lb. Pretty sure I'm gonna roll the fenders. How much should it cost?
| 16x7 +38mm front, 16x8 +0 rear WILL IT FIT? | wildmongoose26 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 02-23-2014 11:04 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
