Old 06-28-2009, 04:55 AM   #19
AlainMikli
AlainMikli's Avatar
thanks guys
actually I'll clean the under panel every time when it's on the rack plus I'll drive very very slow when I see there's any tarmac & water on the road
To do: Supercharger…
Old 06-28-2009, 11:56 AM   #20
speaking of underpanels...
Old 06-28-2009, 08:42 PM   #21
Jerkratt
Jerkratt's Avatar
Originally Posted by Split View Post
Also i can't help but noticing your nitto mid pipe looks different than mine... on mine there is a resonator RIGHT after the o2 sensor which caused the car to idle rough. Looks like its been removed. I had mine cut out and it fixed my problem. looks like nitto figured this out and removed it.
yeah someone ask me that to.. i have one also.. if they fixed the problem then we should be able to send ours back and get one thats fixed! not cool so far.. 2 things ive gotten from nitto where not right.. the torqu dampner ended up making a hole in my strut tower.. and the mid pipe is different and the paper gasket they gave me to attach both halfs of pipe together is blown out already and i got an exhaust leak....
"It hurts more when its wet"
Old 06-29-2009, 04:16 PM   #22
Split
Drives: 2008 Yaris Sedan
yea.. not too impressed with that mid-pipe personally. The axle back is nice though.. its too loud for me, but its still quiet enough for 99% of people buying an aftermarket exhaust.
i'm willing to bet this new mid-pipe fixes the issues.
Split is offline   Reply With Quote
Old 06-29-2009, 04:44 PM   #23
The only reason that would happen to a torque damper is because one or more bolts came loose, or weren't tightened properly in the first place. If it fails, it should be at the rubber joint, not where it attaches to the car.
Old 06-29-2009, 05:12 PM   #24
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Originally Posted by AlainMikli View Post
I think mostly because the Ti-C for yaris can't remove the silencer....or may be I don't know how to take it off...it seems the silencer is welded to the tip itself.....
You can't get it out after you take the tip off? It's in there pretty tight, but it shouldn't be welded.
Old 06-29-2009, 11:34 PM   #25
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I wish I had money like you to upgrade Keep up the good work
Old 06-30-2009, 02:49 AM   #26
AlainMikli
AlainMikli's Avatar
the ring use to lock the screw is welded to the silencer, if I can remove the silencer, that means I can't lock the tip back....you know what I mean
Old 06-30-2009, 03:06 AM   #27
AlainMikli
AlainMikli's Avatar
Just do a little D.I.Y. yesterday, I painted the silencer black because I can't remove it.
Now, it looks better
Old 07-01-2009, 08:17 AM   #28
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
The solution is simple; use a new set of nuts.
Super clean car, btw, nice job.
Old 07-01-2009, 03:20 PM   #29
AlainMikli
AlainMikli's Avatar
thanks, but I still have a hard time to take it out, don't really have a space for me to take it out, super tight
Old 07-02-2009, 02:47 PM   #30
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
looks great! how's the smell now?
808_Yaris Air Runner Thread:http://www.yarisworld.com/forums/sho...655#post329655
808_Yaris Air Runner Video:http://www.youtube.com/watch?v=fUkqox5d5No
808_Yaris Retrofit Projector Pictures:http://www.yarisworld.com/forums/showthread.php?t=22461
808_Yaris is offline   Reply With Quote
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
FS: Megan Racing Exhaust n Header. Sabretooth Items for Sale by private party 6 05-17-2009 05:04 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Exhaust Pipe Size (Tamaño del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
