Old 07-13-2009, 08:00 AM   #1
jonr0613
jonr0613's Avatar
Drives: Yaris Y Sedan
Helicopter noise from the engine???
can somebody help me with this....when i hit the speed of 90 kmh to 120kmh i can hear something like the sound of the helicopter from the engine...but when i hit 130 kmh it will disapper...from 80 kmh below is fine i can't hear any noise....running with windows closed and AC on....
jonr0613 is offline   Reply With Quote
Old 07-13-2009, 10:45 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If it's confined to a speed band, it's likely something loose that's fluttering sympathetically with a vibrational frequency occurring at that speed. It'll take some checking around to figure out what could be loose.
Old 07-13-2009, 03:21 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Try running with the AC off. It could be wheel balance.
Old 07-15-2009, 03:00 AM   #4
jonr0613
jonr0613's Avatar
ok will try running with AC off later...
Old 07-15-2009, 03:15 AM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
check your inner guards and the under panel
Old 07-15-2009, 04:36 AM   #6
YarisSedan
Drives: 08 Yaris Sedan
The plastic lining has broken loose under the car and is either hitting the tire or the ground and flapping as you get high speeds.
Old 07-15-2009, 06:37 AM   #7
jonr0613
jonr0613's Avatar
ok thank guys...will check the car later...
Old 07-15-2009, 07:40 PM   #8
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
remove helicopter from engine bay
problem solved...j/k
Old 07-15-2009, 09:53 PM   #9
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
That's good humor there!!!!
Blue_dragon_192 is offline   Reply With Quote
Old 07-16-2009, 12:03 AM   #10
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
agree :D
btw,don't forget to check the engine mounting
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 07-16-2009, 07:56 AM   #11
jonr0613
jonr0613's Avatar
hahahah that was a good one!!!
well, problem solved brothers....after checking everything in my engine bay for anything loose i found nothing....i went to the local tire shop and had my wheels checked we found uneven parts in the tires (we went off road to dessert several times) so i needed to replace my front tires and it did solved the problem and now my yaris sounds quiet...
thanks a lot guys....
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 11:09 AM
Speakers make noise when engine is on Lafiro In Car Entertainment + Electronics (audio / video / alarm) 13 01-07-2009 09:52 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
excessive valve and or engine noise? thomasward00 General Yaris / Vitz Discussion 3 06-07-2007 01:34 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 11:45 PM
