Old 07-30-2009, 04:34 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
wheelspin problem
hey guys
i got a problem i'd like to get rid of
when i go hot into a corner , and try and give alot of throttle , the front wheels just start spinning , will a sway bar help with keeping the wheels down , here is my setup:
Tein super compact coilovers - 6 front - 8 rear - setting
Tananbe front strut bar
17 inch michilen pilots 205 / 40 /17
tire pressure - 2.4 bar ( nitrogen )
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 07-30-2009, 05:03 AM   #2
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
you do have low profile tires, maybe running on 16s or 15s might help. The sway bar will help your rear end out, at least my friend w/ the Forester says it does for his~
Whats 2.4 bar? what psi is that? I usually run 42psi on my fronts, they spun out couple times under heavy liftoffs lol..
Old 07-30-2009, 05:22 AM   #3
LSD
Old 07-30-2009, 05:36 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i was thinking bout trying 15 inch with semi slicks , might grip little better on the front
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 05:38 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
LSD
hehe , yeah , was thinking bout it , bit pricey though
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 05:39 AM   #6
Wouldn't a bigger side wall cause more tire wall roll?
I say a rear sway bar and stickier tires, and if you can afford it, an LSD (expensive!).
Old 07-30-2009, 05:40 AM   #7
Well, 1 bar is 14.5 psi, so 2.4 bar is about 36 psi.
Old 07-30-2009, 07:20 AM   #8
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
correct , bigger sidewalls cause more movement !! i forgot bout that !! thx
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 10:09 AM   #9
markitect
Drives: Yaris
If both wheels are spinning get new tires.
If only/mainly the inside wheel is spinning then it's probably lifting and a big rear sway bar should help.
markitect is offline   Reply With Quote
Old 07-30-2009, 10:21 AM   #10
sometimes you have to go slower to drive faster....
Old 07-30-2009, 10:42 AM   #11
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , i was thinking the same thing , big rear sway bar !! one from Garm ;-)
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 10:42 AM   #12
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
LOL , true dat !!! i got a heavy foot aswell , hehe !!
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 10:45 AM   #13
well, when you corner hard, the weight transfers to the outside wheels.....so if you're tossing it into the corner too hard and hammering the gas, it doesnt matter how flat your suspension lets you sit, youll still light up the inside wheel
Old 07-30-2009, 12:59 PM   #14
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Like mentioned in the above posts... First you need to tune the driver!!
You already have a VERY capable coilover suspension!!
On a FWD car you need to keep momentum thru the turns a get a good feel of how the weight transfers from front to back...
No matter what suspension you have you can not go full thottle on the curve... you will lift the inside tire no matter what! Practice...! You jave to be smooth on the throttle while going out of a turn.
Once you have yourself dialed in you can start playing with the suspension.
Try soften the front and going stiffer on the back... play with tire pressures also... higher pressure on the back...
The rear sway bar will be a great improvement...
After that if you are still seen alot of wheel spining you can go with a mod that Loren suggested. Disconect the front swaybar of the car.
Make sure you look up Loren's thread first so you understand what are the pros and cons of this mod.
And finally, the LSD. A great but usually pricy $$$ modification.
Old 07-30-2009, 01:15 PM   #15
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
Try 32 psi next time... Your pressures are WAY to high.
Biggie™ is offline   Reply With Quote
Old 07-30-2009, 01:16 PM   #16
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thanks for the imput guys , really appreciate it !! always so good chatting on this forum !!
yeah , i have been trying to spin the wheels on purpose to see what the limits of grip etc are.
i think a sway bar in the rear would be the next upgrade to do for sure , and possibly a bit more grippy tires.
i must say , when i do keep it smooth , the Teins perform really wheel , and really come to life on mountain passes.
i got a few more power upgrades to do , and looks like a local tuner will get the Unichip Q from Dastek to work on my car well. so loads of development to go , and having fun doing it.
JDMtuner
www.jdmtuner.co.za
Old 07-30-2009, 01:18 PM   #17
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
yeah , you right , they are pretty high , but i keep them little higher as we have bad roads with crappy potholes lately , so trying to protect the wheels a bit more.
JDMtuner
www.jdmtuner.co.za
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 01:40 AM
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 10:55 AM
Brake problem 1saneguy General Yaris / Vitz Discussion 15 11-24-2008 04:56 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
