Old 08-20-2009, 09:01 AM   #145
Tamago
Tamago's Avatar
Drives: UZJ100
wow that's cramped! turbo in back + front mount = a pain in the ass... parmas, would you consider doing a top mount intercooler? you'll get better throttle response, less pressure drop, and an overall cleaner engine bay. if an STI can make 350whp+ on a top mount, so can you!
Old 08-21-2009, 12:55 PM   #146
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I have never considered a top mount intercooler since I never liked the design.
In my case if I decided to top mount the ic I am sure that all the heat of the engine and the turbo together will make the ic useless and in the worst case engine damage. I don't exactly care of space, I give priority to performance and efficiency...
Parmas is offline   Reply With Quote
Old 08-21-2009, 12:56 PM   #147
Tamago
Tamago's Avatar
Drives: UZJ100
so you're saying that WRC rally cars are useless? most rally cars use top mount intercoolers. subaru uses top mount
don't be a fanboi... front mounts are overrated.
Old 08-21-2009, 01:08 PM   #148
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Top mount FTW
Its a Chao!!!
Old 08-21-2009, 01:50 PM   #149
pluses and minuses for both, but I always enjoy a good pissing contest, so carry on.
Old 08-21-2009, 02:03 PM   #150
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Haha.
Old 08-21-2009, 02:07 PM   #151
Tamago
Tamago's Avatar
Drives: UZJ100
positives for top mount
1. less than half the piping
2. cleaner engine bay by simplifying piping and routing
3. puts that gnarly scooped hood to actual use
4. does not block radiator (engine runs cooler)
5. can be thicker than front mount because of Euro NCAP (more room under hood)
6. because of the shorter piping, you see less pressure drop and quicker throttle response
7. because it sits horizontally in the engine bay, it can be sprayed with water easily for quick cooling
8. not damaged by road debris
negatives for top mount
1. if improperly set up, will be less efficient at cooling than a front mount
2. it's not "cool" looking. many ricers equate turbos with front mounts, and if you don't have a front mount, you obviously aren't making any power (this really should be a POSITIVE THING not a negative thing lol)
Positives for front mount:
1. looks cool
2. can be generally longer than a top mount (however, short fat intercoolers are more efficient [less pressure drop] than long thin coolers
Negatives for front mount:
1. silly piping running all over the place (in the case of rear mounted turbos, which is what this is about.. in a longitudinal engine, i.e. supra, front mount is perfect because the exhaust is on the passsenger side and intake is on the driver.. obvious routing is obvious)
2. less efficient because of all the extra bends and charge piping bends. every time you go WOT the turbo has to fill the entire length of charge piping AND intercooler before you actually see boost. this can exascerbate turbo lag
3. attracts unwanted attention (law inforcement comes to mind)
4. susceptible to road debris
5. blocks radiator and AC condenser
6. safety may or may not be compromised (bumper beam hacked) to make the IC/piping fit
that's all i have folks.
Old 08-21-2009, 02:21 PM   #152
TheRealEnth
Beast
tell it to em =D
Its a Chao!!!
Old 08-21-2009, 06:38 PM   #153
Parmas
Parmas's Avatar
The only thing for me that comes to a disadvantage is turbo lag.. When I commited myself in this project I was ready to make sacrifices such as no AC and some fitment issues to the front (nothing big though).
In my case a top mount is not suitable mainly because of heat since it would be about few cm infront of the turbo exhaust plus it will be covered with excess heat emitted by the engine. If the turbo was on the rear lower side or at the lower front that would be a different story.
As in terms of space and organization of the engine bay, I see it more nice nd clean at the front which btw that is my opinion on my ride.
Old 08-21-2009, 09:37 PM   #154
^ "attracts unwanted attention" and "susceptible to road debris"? LOL
Old 08-21-2009, 09:58 PM   #155
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
I prefer a V mount intercooler, best of both worlds, rofl. Everything has its positives and negatives, imo you just have to find what setup works best for what you are using the car for. I don't know if that is even possible to put a V mount intercooler on the yaris seeing how short and stubby the front end is.
RacerFreakXXX is offline   Reply With Quote
Old 08-21-2009, 10:14 PM   #156
Tamago
Tamago's Avatar
Drives: UZJ100
hit a nice chunk of retread on the freeway and you won't LOL
Old 08-21-2009, 10:34 PM   #157
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
1. looks cool
not bias at all, of course.
Old 08-21-2009, 11:34 PM   #158
Tamago
Tamago's Avatar
Drives: UZJ100
not at all..
let's see an intelligent bias in the other direction ;)
Old 08-23-2009, 06:42 PM   #159
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Don't you guys have access to barrel type water to air intercoolers over there? Best of both worlds.
rob323 is offline   Reply With Quote
Old 08-24-2009, 06:42 AM   #160
Tamago
Tamago's Avatar
Drives: UZJ100
only if you have a cold water supply (ice chest) in your car.....
Old 08-24-2009, 06:11 PM   #161
rob323
These have proven very effective on high power street cars over here.
Low pressure drop, great throttle response, minimal time required to re pressurise the intercooler tract.
http://www.horsepowerinabox.com/HPIAB2/category76_2.htm
Old 08-24-2009, 08:31 PM   #162
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
only 1600 dollars. fuuuuuuck that
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
