#1 | |
1. less than half the piping 2. cleaner engine bay by simplifying piping and routing 3. puts that gnarly scooped hood to actual use 4. does not block radiator (engine runs cooler) 5. can be thicker than front mount because of Euro NCAP (more room under hood) 6. because of the shorter piping, you see less pressure drop and quicker throttle response 7. because it sits horizontally in the engine bay, it can be sprayed with water easily for quick cooling 8. not damaged by road debris negatives for top mount 1. if improperly set up, will be less efficient at cooling than a front mount 2. it's not "cool" looking. many ricers equate turbos with front mounts, and if you don't have a front mount, you obviously aren't making any power (this really should be a POSITIVE THING not a negative thing lol) Positives for front mount: 1. looks cool 2. can be generally longer than a top mount (however, short fat intercoolers are more efficient [less pressure drop] than long thin coolers Negatives for front mount: 1. silly piping running all over the place (in the case of rear mounted turbos, which is what this is about.. in a longitudinal engine, i.e. supra, front mount is perfect because the exhaust is on the passsenger side and intake is on the driver.. obvious routing is obvious) 2. less efficient because of all the extra bends and charge piping bends. every time you go WOT the turbo has to fill the entire length of charge piping AND intercooler before you actually see boost. this can exascerbate turbo lag 3. attracts unwanted attention (law inforcement comes to mind) 4. susceptible to road debris 5. blocks radiator and AC condenser 6. safety may or may not be compromised (bumper beam hacked) to make the IC/piping fit that's all i have folks.
#2 | |
not at all..
let's see an intelligent bias in the other direction ;)
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Don't you guys have access to barrel type water to air intercoolers over there? Best of both worlds.
only if you have a cold water supply (ice chest) in your car.....
These have proven very effective on high power street cars over here.
Low pressure drop, great throttle response, minimal time required to re pressurise the intercooler tract. http://www.horsepowerinabox.com/HPIAB2/category76_2.htm |
#7 | |
#8 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
#9 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
FMIC Supra Evo's Grand Nationals GLHS RX7 Golf 3000GT Eclipse TMIC WRX CELICA |
#10 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
good points. A top mount will never provide the efficiency of a front mount though. The main reason WRC Subarus use a top mount is so the intercooler doesnt get ripped off landing crazy jumps. And WRC cars im pretty certain don't run on pump gas, so they don't need the cooling efficiency to supress detonation. There is a forumula to calculate temperature drop vs. pressure drop. The benefits of temperature drop far outweigh pressure drop. And also the general formula to see the benifits of temperature drop in the charge stream. For every 10 degree drop is a 1% gain in hp. That may not sound like much, but a good example is my car... I ran no intercooler but with WMI. My MAF sensor temp probe was reading up to 280 degrees @17psi (Blow through set-up, before meth). I just dropped in a Evo intercooler, The charge temps are now the same as ambient, in fact on a few dyno pulls during my last tune the temperature DROPPED a few degrees when boost hit. That's over a 200 degree drop... At the same boost with the same timing I gained 25whp and 32ft.lbs. of torque. Also my spool up is within 200rpm as before, that isnt even noticable. I have installed many front mount kits on STI's and Mazda speed 6/3's. Tuning past 250whp (with top mount) on our dyno is like pulling teeth for gains because of the heatsoak. To prevent risk of detonation more timing needs to be pulled. Any good tuner would agree to that. Even the Cobb base maps for the MS3 are specified for either a top or front mount(more conservative timing for top mount). One thing I constuctively dissagree with is that the engine bay is cleaner with a top mount... I don't think so. Especially with the yaris and Ms3. Just about the only place for the top mount would be on top of the engine cover. I always found it to be a pain to have to remove pipes to service the car. They are routed to where you have to remove them to check spark plugs( which is something to be checked often on a aftermarket boosted car). And on the Subie you have to remove the intercooler to service the transmission /turbo/downpipe. The newer Subies have a smaller sized top mount with composite casing which makes life easier for working on the car, composite casing is for less heatsoak. I say front mount. good build, and whp numbers yet?
Ptuning.com Last edited by Blown_xa; 12-02-2009 at 11:02 PM. |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
