![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
What's wrong with my tach?
So I got this SunPro Mini Super Tachometer II and installed it a couple of months ago. Everything went fine, got illumination and all.
After a while I started noticing that sometimes the needle wasn't moving when it should have been... So I kept an eye on the problem. Here are the observations I made so far. If I turn the key (switch off the engine) too quickly, the needle remains at whatever RPM there was when I started turning the key. If I stop at in the ACC position I can wait for the needle to (slowly - 1-2 secs) come down to zero. I don't know if that makes a difference for the actual problem described below. Symptoms: - I turn the key from OFF to ACC, the needle jumps from zero (or wherever it is) to 1 (1000 RPM) even though I haven't started the engine yet. - When I actually start the engine, the needle jerks a little, but remains stuck at 1. No matter how I rev the engine, the needle doesn't move. - I shut off the engine, turn the key back all the way, the needle goes down to 500 RPM and stays there even if I take the key out. - Usually during my 25-30 min commute, the tach eventually starts working correctly. I never caught the actual moment and how it happens, but I just at some point notice that everything is alright. Does anyone have any ideas? Theories? Has anyone experienced anything similar? I have no idea what could be wrong? Some kind of static charge built up somewhere? No idea, just guessing here... I tried tapping, light and hard, it didn't help.
check that your splice is solid on the RPM wire, and then see if the tach has a warantee on it.
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
Yea my sunpro tach does the same thing and I heavily soldered all the connections. But mines usally does that when it rains, Im starting to give up on sunpro tachs.
Ive had my sunpro 3" tach stuffed into the drivers side center column cubby since I bought the car in May 07 and 75k miles ago, I havent had any issues with mine.
| Installing Speedhut tach, need help! | RedRide | DIY / Maintenance / Service | 2 | 07-05-2009 04:02 PM |
| need a 2" tach, like the cobalt from autometer | severous01 | Cosmetic Modifications (Exterior/Interior) | 0 | 04-20-2009 08:55 PM |
| Tach Installed & Temp Wheels On | justjesus | Off-topic / Other Cars / Everything else Discussions | 4 | 02-07-2009 01:26 AM |
| Installed Tach...Tach works, RADIO doesn't! | 5spBlazer | DIY / Maintenance / Service | 17 | 08-06-2007 08:57 PM |
| How to install tach? | charles nelson | DIY / Maintenance / Service | 1 | 08-04-2007 11:34 AM |
