Old 08-21-2009, 11:03 PM   #19
Yes
Old 09-19-2009, 06:56 AM   #20
kompressorgpl
Drives: yaris 1.0 vvt-i
Hello! I have an alarm to put on my Yaris (from 2002). Where i can find a diagram of the car with that?
kompressorgpl is offline   Reply With Quote
Old 09-19-2009, 09:09 AM   #21
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
use a multimeter and probe the wires, and make your own diagram, thats what I did when I installed my remote starter.
Old 10-20-2009, 01:11 PM   #22
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
hi there,
may i know where can i find this stuff?
regards,
Charles
charleschia1986 is offline   Reply With Quote
Old 10-20-2009, 02:26 PM   #23
Originally Posted by charleschia1986 View Post
hi there,
regards,
Charles
If you mean where are the wires in the picture, they are right behind the pull out pocket on the bottom left of the dash.
Old 10-20-2009, 10:39 PM   #24
charleschia1986
hi there,
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side.
regards,
Charles.
Old 10-20-2009, 11:15 PM   #25
hi there,
regards,
Charles.
In that case it's behind the passenger lower glove box.
Old 10-22-2009, 07:15 PM   #26
Sora65
Drives: Beautiful :)
Correct.
Wait so i can put for than 1 wire in that hole?
Or should i use on of those clip things to wire?
i have no idea about wiring stuff :(
but i really wanna get some lights for the foot area..
Sora65 is offline   Reply With Quote
Old 10-22-2009, 09:32 PM   #27
Use the clip things (tap splices). Just sticking the wire in along side of the existing wire does not make a reliable connection.
Old 10-23-2009, 12:39 PM   #28
Sora65
But where im getting at is right?
i could put the wire i need powered in the same hole as the blue one where theres 12v?
Old 10-23-2009, 02:22 PM   #29
Taboolie
Drives: 07 Yaris
There was a website you could get all of this information from. Most diagrams were on the12volt.com in their forums I think.
Somewhere on there I believe someone posted the login information to get on to one of the installer websites to get access to all wiring diagrams.
I went there to get everything I needed when I put in an alarm/remote starter for my Impala back in the day.
Haven't needed to go back though. Cheers to AllData!
Taboolie is offline   Reply With Quote
Old 10-23-2009, 02:24 PM   #30
Taboolie
Drives: 07 Yaris
Save you the trouble,
<snip from website mentioned above>
TOYOTA / YARIS / 2007 / Remote Start
[PRINT THIS PAGE]
12volts yellow (25A), gray (15A) + ignition harness
Starter black (x2)(common) + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition green + ignition harness
Third Ignition N/A
Accessory white + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock brown - driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock yellow to green (double pulse) - driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motor white to orange 5wi driver kick, 20 pin plug, pin 10
Unlock Motor lt. blue to pink 5wi driver kick, 20 pin plug, pin 20
Parking Lights+ green + fuse box, top L, 30 pin plug, pin 29
Parking Lights- white - headlight switch
Notes: Not available on all models.
Hazards black - hazard light switch
Turn Signal(L) lt. green + fuse box, top L, 30 pin plug, pin 27
Turn Signal(R) yellow + fuse box, top L, 30 pin plug, pin 28
Reverse Light red + fuse box, top L, 30 pin plug, pin 30
Door Trigger see notes - fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervision pink - fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin lt. blue - fuse box, top L, 30 pin plug, pin 7
Hood Pin white - pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer lt. green ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2
Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Headlight lt. blue - headlight switch
Speed Sense purple fuse box, top, 36 pin plug, pin 26
Wipers blue (L), yellow (H) + windshield wiper switch
LF Window up/dn red - green A driver window switch in door
RF Window up/dn white - pink A driver kick, 18 pin plg, pins 11, 10
LR Window up/dn yellow - black A driver kick, 18 pin plug, pins 8, 9
RR Window up/dn red - green A driver kick, 18 pin plg, pins 17, 18
Radio 12v blue + radio harness
Radio Ground white/black - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna black + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- gray - yellow +,- radio harness
LR Speaker +/- black - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
Old 10-23-2009, 03:53 PM   #31
Yes. That blue +12 is always on though. The pink is switched ground for the inside lights.
Old 11-12-2009, 03:04 PM   #32
yoxx
yoxx's Avatar
Drives: toyota yaris 2008 hatch
How to plug in a water temp gauge?
All I really need is the signal for the temp
wich one is it, please HELP
yoxx is offline   Reply With Quote
Old 11-13-2009, 12:46 AM   #33
There's a 2 pin connector to the engine coolant temp sensor. It has a pink and a blue wire that go to pins 96 (pink) and 97 (blue) on connector C20 of the ECM.
Old 11-13-2009, 08:17 AM   #34
yoxx
yoxx's Avatar
Where r this locate it, for some reason I can't find this box you r showing me, been looking under the hood for an hour and I can't find it
Old 11-13-2009, 08:25 AM   #35
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
and the speed sensor wire ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-13-2009, 09:07 AM   #36
With the hood open it is to your left (the car's right) against the firewall. It is the big silver box with the two large connectors.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
