#19 |
Yes
#20 |
![]() Drives: yaris 1.0 vvt-i Join Date: Oct 2008
Hello! I have an alarm to put on my Yaris (from 2002). Where i can find a diagram of the car with that?
#21 |
use a multimeter and probe the wires, and make your own diagram, thats what I did when I installed my remote starter.
#22 | |
![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
hi there, may i know where can i find this stuff? regards, Charles |
#23 |
#24 | |
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side. regards, Charles. |
#25 |
#26 |
![]() Drives: Beautiful :) Join Date: Jun 2009
#27 |
Use the clip things (tap splices). Just sticking the wire in along side of the existing wire does not make a reliable connection.
#28 |
But where im getting at is right?
i could put the wire i need powered in the same hole as the blue one where theres 12v? |
#29 |
#30 |
![]() ![]() Drives: toyota yaris 2008 hatch Join Date: Nov 2008
How to plug in a water temp gauge?
All I really need is the signal for the temp wich one is it, please HELP |
#31 | |
Conn C20.jpg |
#32 |
Where r this locate it, for some reason I can't find this box you r showing me, been looking under the hood for an hour and I can't find it
#33 |
AKA Samurai Racer
and the speed sensor wire ?
#34 |
With the hood open it is to your left (the car's right) against the firewall. It is the big silver box with the two large connectors.
#35 |
The easiest place to tap it is at the speedometer. It is the pink wire in pin 17 of connector D1, which is the larger of the two connectors.
Conn D1 - Combination Meter.jpg |
#36 | |
i got a little problem the water temp that i got, only have one wire for the water temp? wich one should i use for this? the pin 96 (pink wire) or pin 97 (blue wire) |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
