Old 11-16-2009, 02:38 PM   #19
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Originally Posted by jouna View Post
i know some crazy yaris mo fo's and they think the vvt-i is like a vtec and they put the vvti to turn on with a button and it actually gives them 6 whp can somebody explain dis shit!
only VVT-i L is the V-TEC style with 2 cam lobes. it changes timing, lift, and duration
VVT-i L almost doubles horsepower if properly engineered.
plain old VVT-i is not Vtec. single cam lobe. it just changes timing.
127.0.0.1 is offline   Reply With Quote
Old 11-16-2009, 03:43 PM   #20
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I don't think VVT-i as a source of power but more like smooth efficiency. Unplug the VVT-i cam plug and understand what happens. I just want to know that I have all setup right
This thread was created to get to know more on VVT-i tech and how it works aswell though.
Old 11-16-2009, 05:48 PM   #21
127.0.0.1
that is correct. not power, better torque curve on a small motor
for power... you -must- have V-tec, yo.
drop a corolla engine in there
Old 11-17-2009, 05:26 PM   #22
Parmas
Parmas's Avatar
Or VVT-Li is equivalent which is used on various new toyota engines
My mistake just recieved confirmation that ecu is capable to control VVT-i on a single vanos
Vanos definition : http://en.wikipedia.org/wiki/VANOS
Old 11-17-2009, 08:30 PM   #23
ddongbap
Lol why would you call it Vanos?
BTW.
VVT-li is not the same thing as V-Tec. VVT-li is the similar to iVtec. But not the same.
Honda is EPIC at valve timing/adjustments. Nobody has been able to master this realm of crazyness.
Old 11-18-2009, 06:32 AM   #24
Parmas
Parmas's Avatar
VANOS (VAriable NOckenwellen Steuerung)
Old 11-18-2009, 09:30 AM   #25
ddongbap
I know what Vanos is. Its also from BMW, not Toyota.
My previous post, I meant:
Nobody ELSE has been able to master this realm of crazyness.
Old 11-18-2009, 10:31 AM   #26
127.0.0.1
BTW.
that is what I meant. it is the same as v-tec. and as far as no one else has been able to master this ??? ummm....well yes toyota has
Old 11-18-2009, 04:17 PM   #27
ddongbap
No they didn't. The VVT-Li failed, and they stopped production of it.
Vanos is NOT the same as vtec.
Valve timing adjustment is wayyyyyy different than valve lift+duration.
VVT-i = timing.
VVT-li = timing + lift/duration
VTec = lift/duration
iVTec = timing + lift/duration
Vanos = timing
Old 11-18-2009, 04:21 PM   #28
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
oh did they?
then what engine is in this currenty available vehicle?
Originally Posted by xnamerxx
you nailed it sir.
Old 11-18-2009, 05:11 PM   #29
spookz
JDM yO!
Drives: '09 3dr. 5-spd
VVTL-i. =)
Tamago is right, the production of the 2ZZ-GE has been stopped for most markets, however Lotus continue to offer both the 2ZZ and the 1ZZ in their Elise and a supercharged version of the 2ZZ in their Exige.
Old 11-18-2009, 05:20 PM   #30
ddongbap
Sorry, I should have said, Toyota stopped using that engine.
Old 11-19-2009, 08:40 PM   #31
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I just wish that the technology being used in F1 from ages ago would hurry up and get main stream. Solenoid actuated valves. Electronically adjustable lift, duration and timing, and no parasitic losses due as there are no camshaft shafts.
rob323 is offline   Reply With Quote
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 01:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 05:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 05:16 AM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 12:09 PM
