Old 11-18-2009, 03:17 PM   #26
ddongbap
Originally Posted by 127.0.0.1 View Post
that is what I meant. it is the same as v-tec. and as far as no one else has been able to master this ??? ummm....well yes toyota has
No they didn't. The VVT-Li failed, and they stopped production of it.
Vanos is NOT the same as vtec.
Valve timing adjustment is wayyyyyy different than valve lift+duration.
VVT-i = timing.
VVT-li = timing + lift/duration
VTec = lift/duration
iVTec = timing + lift/duration
Vanos = timing
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 11:09 AM
