MPG Hog
Drives: 2007 Yaris Sedan Join Date: May 2010
Door Lock Beep?
Okay, I just bought a 2007 Yaris at a Honda dealership yesterday. When I bought it, the keyless entry was not working. The car was still under Toyota's new car warranty, so I figured I would just go get the remote re-programmed. Well, I got to the Toyota dealership and they looked at the keyless remote, which looks identical to the key from my Corolla, and determines that it is in fact an aftermarket key. He also pointed out that it was not an engine immobilizer key. I did not think to ask at that point how it started the car if it was not one. They did program the key, and it works, however when unlocking and locking the doors, the car does not beep as my Corolla (2009) and RAV4 (2006) both do.
Is the car supposed to beep when you lock the doors via the keyless remote? Should I be concerned with the fact that a non-engine immobolizer key is starting the car just fine? Thanks for your help! |
![]() Drives: Mazda 5 GT 5MT Join Date: May 2010
Only if you have a Toyota anti-theft alarm. Without it, the keyless does not beep.
MPG Hog
MPG Hog
I cant take one and post it right now, but it looks exactly like this one, minus the trunk pop button. There is a Toyota emblem on the backside, but when I was at the dealership, the service guy showed me an authentic toyota remote and the emblem was slightly smaller on that one. He also showed me a bump in the un-cut portion right next to the plastic on the authentic one, which mine did not have.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
AFAIK, the acknowledgement or answer-back function on the keyless remote
only flashes the hazard lights to tell you if the doors are locked or unlocked. Check out page 46 of the Door Lock pdf: http://www.etimago.com/yaris/repairm...oor%20Lock.pdf The above is from the 2007 repair manual that etimago has posted at: http://www.etimago.com/yaris/repairmanual/ CTScott can probably answer your questions about the immobilizer, but I thought I read that the Canadian models had it and the USA models did not, but I don't know that for sure. BTW, here is the link for the Immobilizer pdf: http://www.etimago.com/yaris/repairm...mmobilizer.pdf CTScott would be the expert I presume.
My 2010 has immobilizer but does not beep. just blinks the corner markers. once for lock, twice for unlock. I have thought about putting a relay to beep the horn when it locks.
Learn to Relax
Keyless entry does not beep, lights flash.
I think wanting the beep is very insensitive. I lived in an apartment and one of the tenants bought a jeep and after a week or so had an alarm installed. He would return 1:30 in the morning and set his alarm. The beep would wake me because I had a ground floor apartment facing the parking lot. I thought that person was very selfish and insensitive. |
#9 | |
MPG Hog
The car had keyless anyway with the power package. They just got a replacement remote for some reason or another.
My 2008 Corolla didn't beep, when I asked my dealer why, they said it was because I did not go with the security system.
![]() ![]() Drives: Red Yaris Liftback Join Date: Mar 2009
I have an 07 HB and mine does beep. I had the dealer install the keyless when I first bought it. My remote looks different than the one you posted.
#14 | |
MPG Hog
EDIT: I did some research and found my answer. It was a separate option. Last edited by i<3yaris; 05-06-2010 at 04:04 PM. |
In Canada there is a law that all cars must have it therefore their Yaris's come with it. Most 2007 Yaris in the US did not have the engine immobilizer. If you can take your key to Wal-Mart, have a copy made, and start your car with the copy, you do not have the engine immobilizer.
![]() ![]() ![]() ![]() ![]() Drives: 09' Meteorite liftback Join Date: Jul 2009
i have an alarm on my 09' lb and it doesnt beep and my key is the same as that one ^
i have a '10 and my alarm beeps....70% of the time.
| Disable beep when driver door open and key in ignition | fmicle | DIY / Maintenance / Service | 7 | 05-03-2018 05:30 PM |
| Seat belt reminder warning Beep | Jord | DIY / Maintenance / Service | 28 | 04-09-2009 08:37 AM |
| How do you make keyless beep on unlock and unlocking the car. | marcus | General Yaris / Vitz Discussion | 7 | 04-17-2007 09:53 AM |
| Annoying beep | clayky | General Yaris / Vitz Discussion | 4 | 01-30-2007 03:34 AM |
| How to disable the beep? (ASAP) | Rahxephon | General Yaris / Vitz Discussion | 16 | 06-05-2006 05:03 PM |
