Old 07-08-2010, 10:03 AM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I'm a worry-wort but I worry about RPM's
I finally had my Yaris up to 70 MPH this morning, the tach said 3000 RPM's - my old 4 cylinder Cavalier I traded in only turned over approx. 2000 RPM's at 70 MPH. Isn't 3000 RPM's harder on an engine? I know I'm probably being worried over nothing, but I'm still babying my Yaris since it's only got 550+ miles on it. It feels like a toy compared to driving my old Cavalier. And I used to own a Honda CRX years ago but never paid attention to the tach/RPM's on that car.
DebbyM46227 is offline   Reply With Quote
Old 07-08-2010, 10:11 AM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
cavalier is a different car also sounded like its automatic too.. bigger engine.. vs 1.5 l.... its normal for yaris..
Old 07-08-2010, 10:17 AM   #3
127.0.0.1
3000 rpms is nothing
whether a certain RPM range is hard on an engine is based on
the specific engine and design.
yes... more rpm's are harder on an engine than lower rpm's, but
even 5000 rpm's is nothing for the yaris. change the oil at the recommended
intervals, and wind it to 5000 all day and night, forever. no problem
Old 07-08-2010, 11:32 AM   #4
DebbyM46227
My Cavalier was a 5 speed and a 2.2L engine....but thanks for your opinions. I know I shouldn't worry since it's under warranty for the next 3 years.
Old 07-08-2010, 11:43 AM   #5
Ryude
Drives: 2007 Ford Mustang GT
This is normal for a small 4 cylinder engine with a 5 speed. My Matrix XRS with a 6 speed at 70mph was at around 2800 rpms.
Ryude is offline   Reply With Quote
Old 07-08-2010, 12:09 PM   #6
Absolutely the norm.
The smaller the engine, the higher the RPM. 6 and 8 cylinder engines spin at <2000 rpm at that speed.
Old 07-08-2010, 12:14 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Ahh yea, there's nothing like ramming it up to 5000k to beat people in my little yaris
Old 07-08-2010, 02:29 PM   #8
marcus
toyota
marcus's Avatar
my 1990 celica gts 2.2 liter was running 3200k rpm on 100km.hr yaris is actually lower..
Old 07-08-2010, 03:31 PM   #9
Ryude
Haha, I wish my mustang gt cruised at under 2000 rpm. Currently it cruises at 2500 rpm, but that's because I have 4.10s in it. Stock it's just above 2000 rpm.
Old 07-08-2010, 03:52 PM   #10
STC
"LibertyRides!"
STC's Avatar
Yeah! Displacement is a factor... as well as the other factor - gearing! I would imagine with a 4:11 posi and a large bore cu engine you would be cranking the high RPM's cruising...
Cheers!
~ Mark ~
Old 07-08-2010, 04:08 PM   #11
i drove up to timmins last weekend (about 8.5h drive) doing 130kph/80mph for hours on end....was doing about 3600rpm w/o trouble
Old 07-08-2010, 04:16 PM   #12
Ryude
Cheers!
Honestly I don't see why people don't invest in a 6 speed tranny swap for the yaris, acceleration and mpg would improve dramatically. D-4D Diesel Engine with 6 speed manual from Europe's yaris would give you about 15-20 mpg increase if you know how to drive.
Old 07-08-2010, 08:47 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Give the DIESEL credit for most of that mileage increase.
That said, a six-speed manual would be sweet.
Old 07-08-2010, 09:09 PM   #14
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
I want one! I hate the unnecessarily high RPMs on the highway, and my cruising speed is only 50.
bkrownd is offline   Reply With Quote
Old 07-08-2010, 09:40 PM   #15
Ryude
Honestly I'd pay $2000 for a 6 speed swap.
Old 07-08-2010, 10:07 PM   #16
you guys know that the 6th gear in the c60 tranny is the same as the 5th in our cars, right? its to keep the car in the powerband gear-gear
Old 07-08-2010, 10:34 PM   #17
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
If you're that bad about RPM's then be glad you don't own an S2000. I'm working on getting one of those eventually (need a better job first) but the engine in the first generation revs up to 9,000, and even it's cruising RPM's get pretty high. Kinda similar to Mazda's wankel engine.
Black_griffin6 is offline   Reply With Quote
Old 07-08-2010, 11:24 PM   #18
Ryude
You can't just look at the gear, what is the final drive ratio?
C60
Gear ratios for this transmission.
1st
3.166
2nd
2.050
3rd
1.481
4th
1.166
5th
0.916
6th
0.725
Reverse
3.250
Final Drive
4.529
Toyota Yaris
# First Gear Ratio (:1)
3.55
# Second Gear Ratio (:1)
1.90
# Third Gear Ratio (:1)
1.31
# Fourth Gear Ratio (:1)
0.97
# Fifth Gear Ratio (:1)
0.82
# Reverse Ratio (:1)
3.25
# Clutch Size (in)
- TBD -
# Final Drive Axle Ratio (:1)
3.72
Low rpms with a new battery jaimico DIY / Maintenance / Service 8 04-08-2010 06:17 PM
idle rpms up and down... Nibs General Yaris / Vitz Discussion 10 05-12-2007 03:39 AM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
