you guys know that the 6th gear in the c60 tranny is the same as the 5th in our cars, right? its to keep the car in the powerband gear-gear
#2 | |
![]() ![]() Drives: 2007 Ford Mustang GT Join Date: Dec 2008
C60 Gear ratios for this transmission. 1st 3.166 2nd 2.050 3rd 1.481 4th 1.166 5th 0.916 6th 0.725 Reverse 3.250 Final Drive 4.529 Toyota Yaris # First Gear Ratio (:1) 3.55 # Second Gear Ratio (:1) 1.90 # Third Gear Ratio (:1) 1.31 # Fourth Gear Ratio (:1) 0.97 # Fifth Gear Ratio (:1) 0.82 # Reverse Ratio (:1) 3.25 # Clutch Size (in) - TBD - # Final Drive Axle Ratio (:1) 3.72 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
The more gears,the more work,the more wear!....geeze.
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
You trying to say something?
Tw200--excellent!
No attempt.....already expressed!.
| Low rpms with a new battery | jaimico | DIY / Maintenance / Service | 8 | 04-08-2010 06:17 PM |
| idle rpms up and down... | Nibs | General Yaris / Vitz Discussion | 10 | 05-12-2007 03:39 AM |
| What RPM's are you americans getting on Auto trans? | BMGYaris | General Yaris / Vitz Discussion | 12 | 11-02-2006 02:43 AM |
