Old 07-18-2010, 10:38 PM   #1
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Spring Question
I am looking for an aftermarket spring with the least drop, I don't want to put stock springs back... No control with stock springs ;d, I am thinking of putting NF210s? ARe there any that have less drop? Thanks.
Its a Chao!!!
Old 07-18-2010, 10:48 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Eibatch is only 1" drop.
Old 07-19-2010, 12:08 AM   #3
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
U can do some research about TRD, 1.2' drop, gd enough for me. Mine run on stock shocks, still comfy enough.
beZzZ is offline   Reply With Quote
Old 07-19-2010, 12:22 AM   #4
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
see link for ideas and pictures: "Need a "Mild" Drop"
-toy
Old 07-19-2010, 01:11 AM   #5
NF210's are 1.1/1.2, that is less than the TRD springs, which are closer to a 1.5" drop.
The NF210's are less stiff, only 10% over stock (just to compensate for the shortened spring length)
Old 07-21-2010, 05:17 PM   #6
yarr_is
Drives: yaris
^^ what he says...
http://www.tanabe-usa.com/nf210.asp?id=2
If you want something higher than that.. the why not just stay stock?
Partially Sponsored by:
Tanabe USA
yarr_is is offline   Reply With Quote
Old 07-21-2010, 05:25 PM   #7
tomato
tomato's Avatar
dude, where have you been. PM me.
Old 07-22-2010, 01:52 PM   #8
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
how much is it nf210 ? where can I get them .
yaris4062007 is offline   Reply With Quote
Old 07-22-2010, 03:37 PM   #9
ddongbap
You all should see the under of my car. Its so low, the frame is kinda bashed in. I have a Carbing front control arm bar that was hella bent after hitting a pot hole.
The bottom side of my car looks like that.
Old 07-23-2010, 10:08 AM   #10
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Megan Racing are just 1.5 and cheaper than the others. Check them on ebay...
Yaris_PR is offline   Reply With Quote
Old 07-23-2010, 10:37 AM   #11
i had eibach prokits on the car last winter....loved them, but not low enough for my taste...
with 205-55-15
on winter 185-60-14's
Old 07-23-2010, 12:28 PM   #12
in my store, here:
http://www.shop.microimageonline.com...ris-TNF210.htm
Old 07-23-2010, 02:57 PM   #13
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Don't mean to go slightly off-topic, but if you're looking for the best control without a big drop, you could just save a big buck and run stock springs with a rear sway bar. It's all it really needs.
Old 07-24-2010, 01:46 AM   #14
yaris4062007
trd rear sway bar ?
Old 07-24-2010, 02:52 AM   #15
Ultra Racing, 19mm same as TRD but less expensive, .or
23mm only from Ultra Racing
Both in stock!
Old 07-24-2010, 04:42 AM   #16
yaris4062007
Both in stock!
what's the difference from 19mm and 23mm..
does 23mm handles better then 19mm.
is it easy to install. thanx
Old 07-24-2010, 09:28 AM   #17
detroiter
detroiter's Avatar
Easiest performance mod you could do to your Yaris. The 23mm is a bit thicker so it's going to tighten up things a bit more as far as handling goes (keeping the body roll flat). I'd say with the 23mm that while possible to do, have a friend on hand to help fit it on one side while you get the other. Mine anyways, was a very close fit for where you install it, so it helps to have another hand to line it up.
It's not hard to put on at all though. 4 bolts and your done! The difference it makes is quite surprising, especially the 23mm.
Old 07-25-2010, 03:26 AM   #18
yaris4062007
thanx , will be buying 23mm soon :)
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Question about Spring rate window_lee Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-20-2009 04:22 PM
Spring question? jekqmb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-19-2009 06:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
