Old 04-08-2009, 07:08 PM   #19
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Originally Posted by Nexus1155 View Post
yeah the one that goes straight to the box would never yield gains in something like this, you need to calculate the runner length which is probably what they didnt do the first time around, it takes alot of physics to get these things right! lol
^^ So true ! They also incorporated Velocity stacks inside the plenum of the manifold .
Old 04-08-2009, 08:16 PM   #20
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
Originally Posted by mrbond View Post
Those welds are outta control. They may be technically good, but they just look awful. I'm comparing these welds to those of Fujitsubo and TRD items, though. Geez.
So you'll take visually pleasing over quality? Interesting.
Good luck with that.
Old 09-03-2009, 04:36 PM   #21
cee_dub2003
Drives: Scion xb
I have seen the WR manifold in person and the welds are good.
cee_dub2003 is offline   Reply With Quote
Old 09-03-2009, 05:49 PM   #22
blacksandiegovitz
Drives: 08 Vitz
Yeah there products are legit . This manifold will not be avalible to purchase till december and hopefully by then the Microimage smim will be done
Old 04-11-2010, 08:32 AM   #23
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Anyone fallow up on this?
Old 04-11-2010, 10:36 AM   #24
blacksandiegovitz
Drives: 08 Vitz
I haven't heard or seen anybody on here buy/install one of the weapon r manifolds yet . I did just buy a custom manifold set up for direct port nitrous though ...
Old 04-12-2010, 12:35 AM   #25
hondakiller99
Drives: 05 Scion xA
i actually called weapon r.. they stopped production on the piece because the demand wasnt high enough.. they gentleman also said that there might be issues on the yaris cuz they never tested it, idk maybe someone can clear it up for you guys about that?
hondakiller99 is offline   Reply With Quote
Old 04-12-2010, 03:08 AM   #26
cee_dub2003
Drives: Scion xb
The WR manifold is in stock, and the only reason it might not work on all yaris is that the throttle body is different.
Old 04-12-2010, 11:02 AM   #27
Throttle body angle and number of bolts is different. You'd have to fabricate an adaptor or new flange.
Old 08-25-2010, 06:30 PM   #28
Yarisaur
Drives: 07 Yaris
couldnt we just use the xb throttle body, and swap the electronic components??, I read the xb guys are swaping the 1ZZ-FE throttle body on to the manifolds.. isnt that the same throttle body swap for the yaris?? correct me if im wrong? but i think this can be made to work on our cars with little to no modification..
Yarisaur is offline   Reply With Quote
Old 08-25-2010, 07:48 PM   #29
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
i think the xb TB is not DBW
Old 08-25-2010, 08:13 PM   #30
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
In my case making a flange for adapting the manifold and the TB shouldn't be that hard, I can get someone to do it pretty fast. People here are adapting the Corolla (1.8) stock manifold (I believe its from 1999, witch it metal not plastic) to echos. Still haven't seen any dyno results...
But I have NO money at this moment
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 08-25-2010, 10:41 PM   #31
sleey0
Drives: 2008 Yaris LB
Ain't that a BITCH? lol
I hate it when I run out of money
sleey0 is offline   Reply With Quote
Old 08-26-2010, 08:57 AM   #32
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
What about the old version of the yaris which is DBC. What mods are needed to fit the echo version?
Parmas is offline   Reply With Quote
Old 08-26-2010, 01:06 PM   #33
kou
Drives: 08 lb
Should be the same,no mods needed.
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Matrix 1.8 intake manifold dallas Performance Modifications 4 03-28-2009 01:42 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
