#19 | |
Also, I'm talking with the authorized dealer. they say they can make... |
#20 |
#21 |
my cruise buttons arrived.
i don't know if it will work. the authorized service says we'll try :) is this the right buttons? the right connector? and it has a wire at the back of it. is it normal so is this original? i bought it from ebay as "brand new oem" at this item http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories |
#22 |
It's the correct stalk, but it won't work on your car...
#23 |
#24 |
Start by measuring the voltage on pin 40 of connector A21 on the ECM, with the ignition on, but the engine off. If it measures 12 V, then it it worth a shot, if it doesn't, then stop there.
#25 |
#26 |
Since you are willing to experiment and put some money into trying to get cruise control on your car, another option, which I believe will work on the European Yaris, is the Rostra aftermarket cruise control kit.
It is quite a bit more work to install, but it overrides the gas pedal signal itself, rather than requiring that the ECM do that. The European Yaris uses the same 6 pin connector on the accelerator pedal, with the same pinout as the US one, which is why I think that this should work. There are two versions for the Yaris - An A/T kit ($209) and an M/T kit ($249) http://www.thecruisecontrolstore.com...g/X380183/0003 |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
