Old 09-24-2010, 05:13 PM   #19
Kaya B.
Drives: Yaris
Check out the link below. This Belgium based company makes an aftermarket CC for European Toyotas:
http://www.el-pas.com/products.htm
thank you. I've sent mail to them.
Also, I'm talking with the authorized dealer. they say they can make...
Kaya B. is offline   Reply With Quote
Old 09-24-2010, 09:07 PM   #20
Originally Posted by henry33 View Post
where or how you check this ?
I have copies of the US, European, Asian, and general market electronic parts catalogs. They have the ability to decode the VIN and give the details on the car.
Old 10-01-2010, 03:46 PM   #21
Kaya B.
Drives: Yaris
my cruise buttons arrived.
i don't know if it will work. the authorized service says we'll try :)
is this the right buttons? the right connector?
and it has a wire at the back of it. is it normal so is this original?
i bought it from ebay as "brand new oem" at this item http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
Old 10-01-2010, 03:49 PM   #22
It's the correct stalk, but it won't work on your car...
Old 10-01-2010, 03:57 PM   #23
Kaya B.
Drives: Yaris
Thank you Scott. I'll just try. because if it doesn't work i won't pay for other parts. But if it works i have to pay about 100$ so I need some time :)
I will give you info. Thanks for your helps.
Old 10-01-2010, 04:06 PM   #24
Start by measuring the voltage on pin 40 of connector A21 on the ECM, with the ignition on, but the engine off. If it measures 12 V, then it it worth a shot, if it doesn't, then stop there.
Old 10-01-2010, 04:20 PM   #25
Kaya B.
Drives: Yaris
thank you. i'll try this.
Old 10-01-2010, 04:31 PM   #26
Since you are willing to experiment and put some money into trying to get cruise control on your car, another option, which I believe will work on the European Yaris, is the Rostra aftermarket cruise control kit.
It is quite a bit more work to install, but it overrides the gas pedal signal itself, rather than requiring that the ECM do that. The European Yaris uses the same 6 pin connector on the accelerator pedal, with the same pinout as the US one, which is why I think that this should work.
There are two versions for the Yaris - An A/T kit ($209) and an M/T kit ($249)
http://www.thecruisecontrolstore.com...g/X380183/0003
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
