![]() Drives: Toyota Yaris 2007 Join Date: Oct 2010
How to adjust parking brake?
Anyone know how to adjust parking brake for yaris 2007 sedan?
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Go here:
http://yarisworld.com/forums/showthread.php?t=365 Then go here: http://www.yarisworld.com/forums/showthread.php?t=12333 Bada bing, bada boom- faster than search (**Hint**)
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Can't view the photo's?.Old thread I guess.
Did the adjustment a few days ago.The drums came right off!,no issues.Only moved the star gear about 4 "Clicks".....did some good,but not that much for the e-brake.I did notice some enhanced braking however!....try again next time.Did not want to put Too much drag on the drums. |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I tighten the star wheel way up, to where I can barely (if at all) move the wheel, and obviously can't get the drum off in several thousand miles. It has no effect on MPG as far as I can tell.
Tw200--excellent!
Swidd......tightened the star until you could barely move the wheel?.....Now,are you saying after adjustment,you place the wheel back on and attempt to rotate or you are trying to rotate the unit with just the drum on? (much more difficult to rotate via the drum vs. the wheel being on.).If going that tight it would seem you would "burn-up" the drum and or the pads ASAP!!. Are you also adjusting the "nut" under the e-brake handle inside the car?;if so,is the plastic(s) a PIA to remove for this?. TIA
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| I dropped something down in my parking brake slot... | Boonespeed | Cosmetic Modifications (Exterior/Interior) | 12 | 08-11-2009 09:31 PM |
| Parking Brake Shoe Adjustment | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-14-2009 02:26 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| Parking Brake Adjustment Q's | Lafiro | DIY / Maintenance / Service | 3 | 04-13-2009 08:19 PM |
