![]() Drives: '07 Yaris 3D Join Date: Mar 2011
Console/Radio Illumination
Hi all,
I just purchased an '07 Yaris 3 Door Automatic and find it odd that I can't see any of the console buttons and knobs at night. I've tried messing with the brightness wheel next to the steering column, but nothing. And the only thing that lights up on my radio is the display. I took it back to the dealership today, and my salesman said that's normal. Is it? Because it certainly seems to be annoying. |
That's not normal. Usually people with this issue do as you did and turn up the dimmer wheel. If that's not doing it for you then I'd say something is wrong.
Yeah, I think it's weird too. I've had a lot of cars before, and none of them were completely dark like this one. Sad
there is a setting on the dimmer wheel that will turn all the lights down... perhaps yours is set to that position... try turning it forcefully downwards... i know sometimes at night i purposely drive with my dash and console lights off
If it's not the dimmer rheostat position, check the MET and GAUGE fuses in the under dash fuse panel (literally under the bottom of the dash, by the hood release lever). The prior owner may have had an aftermarket radio installed and popped one of the illumination related fuses when deinstalling it.
Nope, that was the first thing I tried. The dimmer rheostat does absolutely nothing. It's like it's been disconnected or something.
#7 | |
Thanks |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
You sure you have the lights turned on, and arn't just driving around on the daytime lights? That's what I did the first 200 miles when I picked up my '08! I too was puzzeled by the lack of lighted dash controls.... until I figured that they go on just fine when you turn the headlights on!
BTW, when driving at night using just the daytime lioghts, you have NO taillights, that seems like a bad idea. |
Popped as in blown. The fuse cover has a diagram on it that shows which fuse is which.
![]() ![]() Drives: 2010 LB Meteor Metallic Join Date: May 2006
#11 | |
Thanks! |
| 2010 Yaris 3DR LB: Backup Lamp Illumination Distance | msmitka | General Yaris / Vitz Discussion | 21 | 12-27-2011 01:25 PM |
| Light Bulb Numbers For Interior Illumination | privateyeblckbx | Cosmetic Modifications (Exterior/Interior) | 0 | 05-16-2010 04:59 AM |
| part #'s for interior illumination package | bladesmith6 | Cosmetic Modifications (Exterior/Interior) | 4 | 05-03-2010 11:33 AM |
| Tachometer Illumination | Thirty-Nine | DIY / Maintenance / Service | 4 | 05-29-2009 04:59 PM |
| Tach Illumination wire | Liu997 | DIY / Maintenance / Service | 6 | 05-29-2009 11:11 AM |
