If it's not the dimmer rheostat position, check the MET and GAUGE fuses in the under dash fuse panel (literally under the bottom of the dash, by the hood release lever). The prior owner may have had an aftermarket radio installed and popped one of the illumination related fuses when deinstalling it.
| 2010 Yaris 3DR LB: Backup Lamp Illumination Distance | msmitka | General Yaris / Vitz Discussion | 21 | 12-27-2011 01:25 PM |
| Light Bulb Numbers For Interior Illumination | privateyeblckbx | Cosmetic Modifications (Exterior/Interior) | 0 | 05-16-2010 04:59 AM |
| part #'s for interior illumination package | bladesmith6 | Cosmetic Modifications (Exterior/Interior) | 4 | 05-03-2010 11:33 AM |
| Tachometer Illumination | Thirty-Nine | DIY / Maintenance / Service | 4 | 05-29-2009 04:59 PM |
| Tach Illumination wire | Liu997 | DIY / Maintenance / Service | 6 | 05-29-2009 11:11 AM |
