Old 07-20-2010, 12:30 PM   #19
homerj
Safety Engineer
Drives: 09 Fit Sport, 07 Yaris Sedan
This mod makes the headlights turn off when the ignition is turned off, preventing one from killing the battery when accidentally leaving the headlights on. With this mod, in order to leave the headlights or parking lights on, the key will need to be in the ignition switch and turned to the on position....
remote start systems sometimes turn on the parking lights. would this diy affect that?
EDIT W. ANSWER: It wouldn't because a) the ignition would be on and b) it works after the switch and turns it on directly
homerj is offline   Reply With Quote
Old 07-20-2010, 01:17 PM   #20
That's correct. I installed a remote starter on mine and the parking lights still come on when I remote start or flash when I lock/unlock.
Old 12-29-2010, 01:49 AM   #21
wshing
Drives: Yaris
I hate to bump this old thread, but I was wondering can I just strip the wires, solder them together and heatshrink instead of getting 12VDC/10A DPDT Plug-in Relay.
wshing is offline   Reply With Quote
Old 12-29-2010, 07:25 AM   #22
You really want a relay in there to keep the headlight and ignition circuits separate. The relay allows one circuit to switch the other, without being a direct connection.
Old 12-29-2010, 02:04 PM   #23
wshing
Drives: Yaris
ah thanks CTScott. I'll go get that relay, haha havn't been to radioshack in ages.
Old 01-06-2011, 05:34 AM   #24
arteunporro
arteunporro's Avatar
Drives: yaris 2010 1.33 TS
I can't find any shop who send to spain this relay! :'(
arteunporro is offline   Reply With Quote
Old 01-06-2011, 07:29 AM   #25
It doesn't have to be that exact relay. You just need a DPDT relay with a 12 VDC coil.
Old 01-07-2011, 12:46 AM   #26
arteunporro
this could be work, isn't?
http://cgi.ebay.es/Relay-Picker-Comp...#ht_2072wt_709
Old 01-07-2011, 06:34 AM   #27
Yes. That one is fine.
Old 01-07-2011, 08:08 AM   #28
arteunporro
thx!
Old 01-15-2011, 08:50 PM   #29
arteunporro
it's done! :D:D:D
thank u so much CTScoot :D
Old 01-16-2011, 07:48 AM   #30
ibanezjeepguy
Drives: 2010 Meteorite Liftback
I'm wondering if 2010+ models have this issue, I cannot remember having the lights stay on after I took the key out... they might have though!
ibanezjeepguy is offline   Reply With Quote
Old 02-19-2011, 11:52 AM   #31
nOmi_89
Drives: 2007 Toyota Yaris
Talking
awesome thread :) i'll be doing this soon enuff :P hope it works fine for meeee :D
thread Subscribed lol :D
nOmi_89 is offline   Reply With Quote
Old 02-19-2011, 05:35 PM   #32
ibanezjeepguy
I know what it was... with our 2010 LB, it is possible to leave the front map lights on accidentally! my wife has done this twice now, at least that I've caught, I would love to add a small chime to that circuit for when the key is removed.
Old 04-01-2011, 09:42 PM   #33
iicaie
Drives: Vios E
Nice work Scott! Correct me if I'm wrong, but if I want to have a relay that will turn on/off something when the key is in/out, I just put a 12V relay in-line with the pink wire?
iicaie is offline   Reply With Quote
Old 04-01-2011, 09:46 PM   #34
Correct
Old 04-30-2011, 07:50 AM   #35
azeeroth
Drives: '09 Yaris
Sorry for thread digging of sorts, but this page has been massively useful for a couple mods I've done to the Yaris here now.
I just did this mod to my Australian 5 door 2009 Hatchback (LB?) and it works a treat - but I did notice a couple differences.
1) All the controls are on the right hand side, must be an Aussie thing
2) More importantly - the T1 cable on my Yaris was a thinner Green cable, not a black/white cable.
The ED cable was the type indicated by CTScott. Apologies if this is me missing something obvious, but it messed with my head! Nearly gave up on the mod but after some probing and theorising and a good old bit of bugger it what's the worst that can happen I went ahead and it's all good. No more beepies for you my little Yaris!
Hopefully that green cable doesn't do something important
azeeroth is offline   Reply With Quote
Old 01-26-2012, 11:29 PM   #36
yarisyeti
Drives: 2011 Yaris 3d LB
Would this work: http://www.ebay.com/itm/1-PCS-12V-DC...item1c1d3e6219
I live in the country, and having a light to see where I'm walking from my car to my house would be nice, and I think this would be ideal.
Thanks!
(just call me the old thread resurrecter!!)
yarisyeti is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
