Old 07-20-2010, 12:30 PM   #11
homerj
Safety Engineer
Drives: 09 Fit Sport, 07 Yaris Sedan
This mod makes the headlights turn off when the ignition is turned off, preventing one from killing the battery when accidentally leaving the headlights on. With this mod, in order to leave the headlights or parking lights on, the key will need to be in the ignition switch and turned to the on position....
remote start systems sometimes turn on the parking lights. would this diy affect that?
EDIT W. ANSWER: It wouldn't because a) the ignition would be on and b) it works after the switch and turns it on directly
homerj is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
