Old 05-25-2011, 12:19 AM   #19
Happy Little Pony
Drives: 2007 Yaris HB
Originally Posted by BLOODY_STONE View Post
big THANX!! considering synthetic oils ... what do you recommend?
It's hard to say, not knowing what's available to you there. Any synthetic oil that's rated "SL," "SM" or "SN" by the API, or "GF4" or "GF5" by ILSAC would be fine.
Happy Little Pony is offline   Reply With Quote
Old 05-25-2011, 04:47 AM   #20
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
mobil 1 , castrol , shell , total ... All are API SL
We got some good stuff ... I think i'll buy my oil next time from saudi arabia (the country in the movie kingdom :-D) since they are leading in oil industries ...
BLOODY_STONE is offline   Reply With Quote
Old 05-25-2011, 06:01 AM   #21
Kongo-Otto
Drives: '09 Yaris & '10 Auris
I don't think it does matter if a country is leading in flowing oil. Engine Oil quality depends on other things.
Old 05-25-2011, 01:17 PM   #22
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
In Russia very much appreciate Mobil 1 Synthetic
MickZEL is offline   Reply With Quote
Old 05-25-2011, 07:32 PM   #23
BLOODY_STONE
other suggestions ?
Old 05-26-2011, 02:41 AM   #24
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
for me I used the Toyota genuine motor oil and changed every 2500km as the oil is cheap. I am not that fan of synthetic due to coating effect.
Trust me, changing oil in shorter intervals will have engine longebility and far more better than using long interval synthetics.
I live in Saudi Arabia on extreme HOT and sandstorm weather conditions....HiH
ricepower is offline   Reply With Quote
Old 05-26-2011, 07:13 AM   #25
BLOODY_STONE
THNX! i buy my oil from Saudi Arabia too!
Old 05-26-2011, 03:48 PM   #26
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Mobil1 is probably a similar formulation world wide, here in Canada i use Mobil1 5w-20 in the winter and 10w-30 in the summer, changing at 10,000kms intervals,
Old 05-26-2011, 11:02 PM   #27
GeneralDon7
Drives: Yaris Sedan
For me I use Mobil1 5w-20 with a royal purple filter at 7500 mi intervals.
GeneralDon7 is offline   Reply With Quote
Old 06-06-2011, 05:37 AM   #28
BLOODY_STONE
all u guys use mobil 1 ? looooooool
k
i'll try to find one not locally made in Egypt it will be much better ...
last thing
what does ''multi grade oil '' mean ? means synthetic?
Old 06-06-2011, 09:54 AM   #29
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Use Mobil 1. I used Valvoline this past oil change and I'm at 6600 KM and it's already dark brown. I got to 10k last time with mobil 1 with a few thousand kms to go still.
Old 06-07-2011, 06:47 AM   #30
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
"Multigrade oil" refers to an oil which can simultaneously meet certain low temp and high temp viscosity requirements. It does not necessarily mean an oil is synthetic but 0W grades are usually syn blends at a minimum. It does tend to be easier for syns to meet multigrade standards with less use (or non use) of additives such as pour point depressants and viscosity index improvers.
Here is an Amsoil document that explains this concept.
http://www.workablewebtools.com/site...multigrade.pdf
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-08-2011, 10:45 AM   #31
R2D2
Crazy Oil Sniffer
R2D2's Avatar
OP,
Here is some additional info on viscosity which may be easier to understand.
http://www.bobistheoilguy.com/motor-oil-101/
R2
-The Fitful One
Old 06-09-2011, 07:30 PM   #32
BLOODY_STONE
Originally Posted by R2D2 View Post
OP,
R2
Engine oil pump? zahirrahman DIY / Maintenance / Service 3 09-30-2010 02:06 PM
Performance engine Oil xbalance Performance Modifications 2 07-14-2009 04:32 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 12:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
