Old 05-24-2011, 08:19 PM   #14
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
Originally Posted by Happy Little Pony View Post
Exactly. In an ideal situation, you can run a synthetic oil longer than a conventional because the synthetics tend to have a more robust additive package. But, as you describe, you live in less than ideal circumstances in a very dusty environment. That will be your problem. Keep an eye on your air filter and your air intake, making sure all of the seals are good and that there are no cracks or leaks. That will have more to do with you engine's lifespan than the oil will.
But especially keep watch on your cooling system. Check your coolant level regularly and watch for leaks! More engines end up on the scrap heap from coolant problems than from oil problems.
big THANX!! considering synthetic oils ... what do you recommend?
BLOODY_STONE is offline   Reply With Quote
Engine oil pump? zahirrahman DIY / Maintenance / Service 3 09-30-2010 01:06 PM
Performance engine Oil xbalance Performance Modifications 2 07-14-2009 03:32 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
