Old 03-04-2007, 11:42 PM   #1
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Exclamation Rattling Noise with A/C Fan?
I just took my Yaris out for a drive today and noticed a little rattle when I turned on the fan, it stays on whether or not you have the Compressor running, but only gets worse when you turn the AC speed higher...
Hence through the sciences and genious that I had acknoledged, it has to be related to the Fan. So jus wondering if anyone else has had this problem?
Of course this is a warrenty thing, but will they try and give me crap for my Rims?
Old 03-05-2007, 06:08 PM   #2
silveryarisdriver
SilverYarisDirver
Drives: 2007 Silver Yaris Sedan
i have the same problem. the dealer told me its the heat shield. he said a lot of yaris folks have benn complaining about it lately. he said he could quiet it a bit with a modification but most likely it'll still rattle a bit now and then.
silveryarisdriver is offline   Reply With Quote
Old 03-06-2007, 03:28 AM   #3
Sabretooth
37HSSV
Sabretooth's Avatar
If it is a common problem within the new US Yaris', could it be time for a recall? But it is more of an annoyance than a safety concerne
Old 05-13-2007, 02:06 PM   #4
beep
Drives: Yaris TS
Hi
I'm a user of previous version of yaris. It's TS (toyota sport) with 1.5l engine and I have similar problem. Sometimes it rattles sometimes it doesn't. Can you tell me where this heat shield is?
beep is offline   Reply With Quote
Old 05-13-2007, 02:40 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
PFFFT . The real problem is that a small leaf or pine straw or dead bug went into your fresh air duct . The object is now lodged in next to your fan . It will eventually come out . Use the "fresh air" knob and also use the foot only vents . Let gravity do its job .
Old 05-13-2007, 02:41 PM   #6
kaboom
kaboom's Avatar
Drives: 2007 silver yaris sedan
why should they give you crap for your rims ? just make sure they have a factory offset ( i believe about + 40 mm)
kaboom is offline   Reply With Quote
Old 05-13-2007, 02:44 PM   #7
kaboom
kaboom's Avatar
;p.s. my avatar pic is showing a subaru outback drawn by a donkey after a disgruntled japanese customer made his point just outside of subaru dealership in nagoya - the white/red banner says : SUBARU IS A PIECE OF SHIT. DO NOT EVEN THINK ABOUT BUING.
hahaha
Old 05-13-2007, 02:46 PM   #8
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
i have the same rattle probls when ac or heat or fan on, but when i turn it off. nothing at all.
But recently i heard my engine noise when i'm stopping. not that loud, but kindda annoying.
jamal1984 is offline   Reply With Quote
Old 05-13-2007, 03:14 PM   #9
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Blower
Pull the glove box and open the EMPTY filter housing. You can look right down at the fan when you do that. The next step is to turn on the fan and visually inspect the fan body assembly for debris being blown in to your face.
blacksan is offline   Reply With Quote
Old 05-13-2007, 03:22 PM   #10
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Yeah , ....what he ^^^^^^ said
Old 05-14-2007, 03:21 AM   #11
beep
Drives: Yaris TS
I pretty sure the rattling comes from engine bay not from the fan below the filter housing but I will check it too.
Another thing is that rattling stops when I rev the engine a little bit.
Old 05-14-2007, 04:09 AM   #12
blacksan
blacksan's Avatar
Oh. you where told it is possibly a heat shield on your exhaust? If so then it might be a bracket that is cracked on the heat shield. That same thing occured to me several years ago on another vehicle. I just pulled the shield of and had it welded.
BTW, how many miles on your car?
Old 05-14-2007, 03:39 PM   #13
beep
Drives: Yaris TS
The car has around 50.000 mileage now.
I went to a local toyota garage and they told me it could be the compressor but they are not sure as the rattling didn't happen when I was there. It is strange to blame compressor as the rattling stops when I rev the engine a bit
Old 05-14-2007, 04:24 PM   #14
blacksan
blacksan's Avatar
If the AC compressor is making noise it might not have enough refrigerant in the system. Do you ever have the AC serviced before?
Old 05-14-2007, 05:51 PM   #15
beep
Drives: Yaris TS
Yes, I have it serviced 2 months ago.
Old 05-14-2007, 07:59 PM   #16
blacksan
blacksan's Avatar
Did it rattle before that service?
Old 05-15-2007, 03:27 AM   #17
beep
Drives: Yaris TS
Yes it did
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
A/c blower motor noise!!!! LBdriver General Yaris / Vitz Discussion 28 09-12-2007 07:46 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
Noise in the A/C System cburac DIY / Maintenance / Service 1 05-16-2006 06:14 AM
