#19 | |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
#20 |
Anything that will let you past the rev limiter, and control the VVTi.
![]() We had a custom harness made that allows us to piggy back an AEM EMS series 2. There are other options out there, none of which are cheap. But without ECU control any mods, including FI, are compromised.
#21 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Good advice was given for sure. If you go boost, keep it at a 40whp gain and no more if you want it reliable on a stock motor for track abuse. I say 40whp gain instead of a specific number because dynos vary. Get a baseline number, and use that same dyno later for reference. I popped rods many times at 150whp (our dyno) and it is never fun to invest $500 entry fee and go home on a tow truck. I must have done 6 Time Attacks at 130whp and never had issues. It was enough power to podium many times in street fwd, as long as you are a decent driver and you have everything else dialed in.
Ptuning.com |
#22 |
advocatus diaboli
Great thread.
#23 |
![]() ![]() Drives: 09 Yaris RS Join Date: Aug 2010
Brakes are a must thats for sure. If i can put my input into this id say get braces as a 1st suspension mod. IMO is prolly the best mods done that ive done yet. without them i felt that the body was working too much. i got the 3 underbody brace from UltraRacing and it really feels good now. Just going over a speed bump you feel that the body of the car doesnt wobble as much. The car feels a lot stiffer and when i push it I like the feel that Im into a solid car. I got coilovers and RSB as well but my 1st mod was the braces and I can defenitly say that i got better benefit from those mods that the shitty tein basic coilovers i got
I starting doing some laps in the car fully stock except for advan a032r tires. In a way I am building the car to what my track sessions tells me can be improved. So my setup was the braces ---- RSB ---- Coilover(which I really really really dislike) and alignment at same time. The car is tail happy with me driving but I am really rough on it when doing my inputs. I have to improve that a lot (my racing instructors loves to ride with me but say ill kill the direction of the car really fast.) The front bushing where torn at 33000km?. Anyway. Go out there do some laps and build it from there is what I would say more than try this try that. We all drive differently and you build it for your driving habits not some other person. It's ur money! |
#24 |
I like braces. But I think if you wanna track a car the first thing you should invest in is a roll cage an fire extinguishing system. But I am a little confused what the OP goals are for.
Just simple PDX track events are great and fun and you dont need all the safty equipment. Then you mentioned autocross which those braces will put you in SM class. IF you run track events and build it to a specific class there. You may end up in a non competitive class in autocross. Most of the guys who run track events use autocross to dial in thier cars a bit more and just fill in the gap between track events. They usually run Prepared class's. Depends what type of racing you wanna do to be competitive in. Last edited by ilikerice; 07-23-2011 at 06:54 AM. Reason: wording |
#25 | |
#26 | |
Only Happy When it Rains
Colin Chapman disciple |
#27 | |
I can't think of any reason it would not work for a daily driver. The solid hub is not as smooth as a sprung one, but you really only feel it in 1st gear.
#28 | |
#29 | |
![]() ![]() Drives: 2zz MR-2 Spyder Join Date: Nov 2010
#30 | |
2ZR swap. DO IT! Ask how!
![]() Looking at the C50 repair manual gives much better illustrations, so I'm thinking it's actually the gear that attaches to the differential? If so, then wouldn't the entire output shaft also have to be replaced?
#31 |
#32 |
+1, the final drive + the output shaft.
#33 |
Mr. 155 and climbing
This is an awesome thread and giving me much more useful info than I knew about this car. It could greatly shift my plans. Great way for the OP to start things.
#34 |
So after poking around for part numbers with the xB transmission, it looks like in '07 they went with the E351 instead of the C50 (due to engine change). This would mean that only an '06 or older xB/xA tranny would have the desired output shaft and gear ring? (I looked into the part numbers and they match for xA/xB).
How can it be the same transmission (C50) if it has different gear ratios inside? Seems like that would warrant a sub-designation or something to make it apparent, especially if I were to go to a junk yard and try to find one. |
#35 | |
Jason posted the xB part numbers needed:
#36 |
Is there a difference between the old/new parts? Some sites don't have the new numbers, so here's the old ones:
33321-17011, output shaft 51221-12340, ring gear 90105-11040, ring gear bolts (8) (no change) At this point, I'm going to either make a new thread or keep chasing these ideas on the xB final drive swap thread Last edited by CrankyOldMan; 08-06-2011 at 09:20 PM. Reason: researched speedo gears... and then read the other post about final drive swap... |
| Persuade me to buy a Yaris! | TONIZZLE | General Yaris / Vitz Discussion | 48 | 09-09-2011 11:31 AM |
| Why does the wind move my Yaris HB all over the highway? | Syroyizhka | General Yaris / Vitz Discussion | 19 | 12-29-2010 03:41 PM |
| Yaris TS 1.8L History and Specs | CASTREX | Yaris TS Talk | 52 | 10-27-2009 05:06 PM |
