Old 08-26-2011, 11:55 AM   #1
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
07 wont start, no dash lights, battery good
07 LB wont start, does not turn over even, no noise. All other features, radio, overhead light, headlights still work fine. Yet only headlight indicator is only dash light that will come on (when i turn on lights), otherwise no dash lights, carwont turn over. It will push start
Got boost?
etheliters is offline   Reply With Quote
Old 08-26-2011, 11:56 AM   #2
etheliters
etheliters's Avatar
Battery and alt are new, been in for about 1 month
Got boost?
Old 08-26-2011, 12:04 PM   #3
yrsgirl
Drives: 07 yaris two door liftback
starter bad? or wire to the starter?
yrsgirl is offline   Reply With Quote
Old 08-27-2011, 04:16 AM   #4
etheliters
etheliters's Avatar
thats what i hope, but why no dash lights?
Got boost?
Old 08-27-2011, 10:21 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Have you checked all the fuses? in the car and under the hood.
Old 08-27-2011, 10:36 AM   #6
AM2 fuse in the under hood fuse panel.
Old 08-27-2011, 05:18 PM   #7
etheliters
etheliters's Avatar
And the winner is.... CTScott. AM2 Fuseblown. swapped and I'm ok now. Thanks soooooooo much guys. Its so painful to be told by the dealer that they wont even look at my car with the s/c on it.
Got boost?
Old 08-27-2011, 05:19 PM   #8
etheliters
etheliters's Avatar
CTScott, how did you find it? Do you have a service manual or alldata?
Got boost?
Old 08-27-2011, 05:19 PM   #9
etheliters
etheliters's Avatar
Why did it pop in the first place I wonder....
Got boost?
Old 08-27-2011, 07:10 PM   #10
BLH
Drives: 2007 Yaris Sedan
There is a sticky thread at the top of this section.
It has links to the 2007 service manuals in it.
BLH is offline   Reply With Quote
Old 08-27-2011, 10:05 PM   #11
AM2 is the main fuse for the ignition circuit. Anything using ignition switched power could pop it if shorted, or if you have too much hung on that circuit for the fuse, that could also cause it.
Old 01-14-2016, 01:16 PM   #12
serge19
Drives: Yaris Hatchback 2007-Automatic
Many Many Many.....thanks to CTScott, you saved me
Spent almost all day to figure-out...changed relay and all (stupidity checked AM2 in rush too)...You are genius...StayBlessed
I have a question, what is the reason for that... I hope coz of remote starter installed in car..??
serge19 is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
Good place to find constant & switched 12V behind dash? atebit In Car Entertainment + Electronics (audio / video / alarm) 16 03-03-2009 11:40 AM
Brighter Dash lights, there is a switch??? mgthompson General Yaris / Vitz Discussion 14 04-04-2007 09:51 AM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 12:37 PM
