Old 10-08-2011, 10:54 PM   #235
carlosgil5
Drives: 2010 AT 5dr Liftback
I just ran your VIN through the EPC and your car is actually a Canada spec, not Mexico spec Yaris, so cruise will definitely work for you. I suspect that even for Mexico Spec cars that it will work as well.
thanks for the quick reply.
are you still selling the cheap OEM cruise control stalk & connector cable?
I have a US based shipping address in Nogales, Arizona
carlosgil5 is offline   Reply With Quote
Old 10-08-2011, 10:58 PM   #236
Yes. I still have the Stalks with CC wire and mounting screws for $40, as well as the pins needed for 06-08. Theoretically your 2010 AT only needs the stalk, since the US and Canadian 09+ Yaris have the wiring in place, but you may want to take a peek at the ECM connector and the spiral cable connector to be sure.
Old 10-09-2011, 12:39 PM   #237
ZeeGrandChamp
Drives: 2010 3-Door
Did the CC upgrade on my 2010 USDM 3-Door... as easily as changing a shift knob. CTScott's kit is great and the updated part number for the cover is:
45184-52130-B0 and the list price is about $32.00
ZeeGrandChamp is offline   Reply With Quote
Old 10-09-2011, 03:58 PM   #238
carlosgil5
Please PM me your info.
Can't wait to do this, If the wiring is already in place a friend of mine with a 08' sedan can use the extra wire.
Thanks for the help.
Old 10-09-2011, 04:01 PM   #239
carlosgil5
thanks for the info, but I think am gonna' drill. I'll be very careful.
Old 10-16-2011, 04:28 PM   #240
carlosgil5
Well, am in trouble, I picked up the package, thanks for the kit, everything came in time and as expected.
Drilled the cover, installed the stalk with the wire, did a road test and it's not working.
I definitely need help here guys.
What do you think, the 06-08 method?
Looks like this is going to be a learning experience for the people with Yaris bought in Mexico.
Old 10-16-2011, 07:07 PM   #241
Can you take a measurement on the wire that goes to the ECM pin. With the ignition on and none of the stalk switches pressed, it should read +12V.
Old 10-17-2011, 04:38 AM   #242
carlosgil5
I could not get any measurement I have one of those little harness plugs in the hole where pin 40 would be.
This are the connections under my steering wheel.
there's no blue and no brown wire.
This is my cluster showing the cc icons.
So I have to run the wire from which hole in the connector?
What else do I have to do, I already drilled the cover, plugged the stalk wire and bolted the OEM stalk.
I was really hoping my '10 AT had all the wires in place. Not at all.
Old 10-17-2011, 07:35 AM   #243
So, you definitely need to add the connector D3 pins. The other question is if the ECM connector A21, pin 40 is present? On Puerto Rico spec cars, it is, but the D3 pins are not.
Old 10-17-2011, 02:45 PM   #244
carlosgil5
Am getting a little nervous about this, I unplugged the ECM connector A21, looked at the pin 40, small pin by the way, and looks like there´s nothing there, just the empty space, It was late and dark, of course I´ll double check at lunch time.
Now my concern is with my ECM, in theory I have the one used in the canadian Yaris (89661-52G71), but, what if there´s nothing on my ECM to receive the wire in the ECM connector A21 pin 40? would that mean I have the cruiseless euro type of ECM (nooo please)?
Oh boy am in panic.
Old 10-17-2011, 03:38 PM   #245
Oh boy am in panic.
89661-52G71 is a US/Canada spec ECM, so I am sure that you are OK. I should have made you check the ECM and connector D3 pins before I sent you the stalk.
Old 10-17-2011, 04:22 PM   #246
carlosgil5
Hey CT you have been of great help, definitely my bad, since I have a ´10 I tought I had the wires in place and I was lazy to unbolt stuff and take a look.
Ok, so my next step would be Vince87´s method right?
I already downloaded the PDF and read the entire thread.
wire from AD3 to ECM connector A21 pin 40 right?
Old 10-17-2011, 04:29 PM   #247
Correct - Wire from A21-40 to D3 and D3 to ground. I can mail you the pins (ECM pin - $5, D3 Pins - $5). USPS to Mexico is the same as to Canada, so there would be no extra charge for me to ship them to you directly (rather than to your US address).
Old 10-17-2011, 04:46 PM   #248
carlosgil5
Wow, sounds great.
Do you know if USPS offers a faster shipping speed?, I am willing to pay a little more for a faster shipping and get this done.
Old 10-17-2011, 05:41 PM   #249
Wow, sounds great.
Priority mail (6-10 business days) would be $13 more and Express mail (3-5 business days) would be $30 more.
Old 10-17-2011, 07:56 PM   #250
carlosgil5
Ok, I think 3-5 bussiness days are too many days (expensive too), I am going to buy some 20-24 AWG wires and try to make the connection myself. Are these wires made from many thin wires or 1 thick one.
If I can´t make it work, I´ll order them from you.
Sorry for so many questions I do not have electronic experience in cars.
I am very grateful, Thank you.
Old 10-17-2011, 08:14 PM   #251
For testing purposes, stranded wire should work. You will probably not find it to be reliable for continued use though, without using connector pins.
Old 10-17-2011, 09:46 PM   #252
carlosgil5
PM sent.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
