#19 |
The part numbers for the Vitz RS 2012 tails (complete assembly) are:
Right:81550-52841 Left: 81560-52781 Your French made 2012 tail lights (lens and body) are part number: Right:81551-0D370 Left: 81561-0D370 Unfortunately the EPC doesn't show the connector detail to determine if they are the same.
#20 |
![]() Drives: Toyota Yaris 2012 Join Date: Mar 2012
True I do not have to sell just said so due to the frustration at the time.
Ctsscott we do have the serials on the rear light combination thread I have up. There was only numbers on the light bulb housings , which would probably be the same as yours. Anyways I'll re take it apart tomorrow and get some clean snaps , did take one for the whole tail , will post it up bit jater but comparing with the serial I posted, it looked like it had only 2 wires. But quite frankly it'd be stupid to have different connector, but the rs has less cables that I'm sure off, seen my buddy work with the new Audi and the LEDs had less wire. But we all know the japs like to make things, slightly " smoother" ( irony ). So in essence I can order them worst case scenario is the re wire Last edited by Ladbrox; 04-12-2012 at 07:54 PM. Reason: Added some led bout audi |
#21 |
The Audi ha the same connector just less wires!
| Broken top plates and end links | Trish | General Yaris / Vitz Discussion | 0 | 04-07-2011 12:28 PM |
| sway bar links contd | jstantherprsn | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-26-2011 02:58 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
| Review: Adjustable Sway Bar End Links | m911gt | Performance Modifications | 9 | 04-29-2009 09:25 AM |
| T-Sport Tail light Sales Links | Yaris TTE JWRC | Cosmetic Modifications (Exterior/Interior) | 8 | 01-23-2007 11:07 PM |
