#73 | |
![]() Drives: ECHO NCP-12/2NZ-FE Join Date: Jun 2012
But the thing is i need the code to find it easy, there are allot gears sitting over There and that will take my time to search for it and i have a to get some part's for a friends and to buy a car too that is the case.
#74 |
![]() OK i find this Code do you have it on your transmission, Note the number is 12 which means C160 (6-speed). On the Wikipedia site it says (Transmission with identification code ending with 12C are LSD equipped. Code ending with 12A are non-LSD). http://en.wikipedia.org/wiki/Toyota_C_transmission#C160 C160 ratio info.
#75 |
cool, I never noticed that there, I'll have to look on mine. I take it that's on top?
Actually, if that's on the bell housing, I don't have that anymore. It was sold with the rest of the 5 spd a long time ago. |
#76 |
Some Search TRANSAXLE ASSY part no..
TRANSAXLE ASSY, MANUAL ( 30300‑1A260 ) C160-12C LSD 1999 TOYOTA LEVIN (AE111-ACFVF) LVN BZR JPN CP 4AGE MTM 6F Link http://autoconnectioninc.net/DaCart/...oducts_id=8093 ![]() 30300-1A260 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZR ***6-speed*** 30300-1A250 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZG..6F 41301-12041 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE11#..MTM..(BZG,FZ,XZ) 41301-12190 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE111..MTM..(BZR,BZV) ***LSD? *** Last edited by Hussain-Vtec; 06-27-2012 at 08:15 AM. |
#77 |
![]() Drives: Toyota Echo Turbo Join Date: Nov 2013
Dude I've been searching for ages trying to find the C160.
I have come accross a few but they dont look the same as yours ![]() They all say in their ad that they're a C160 but Im not convinced. They look completely different. Could it be the year model? What did yours come out of? I've attached some images, yours is the one with 3 question marks, the other is one I have foung elsewhere (1 question mark). Also here is a link to another one on ebay (http://www.ebay.ie/itm/JDM-Toyota-Co...#ht_783wt_1114). I get that its sold but it looks different too?
#78 |
Mine is pictured re-assembled with the 5 spd bell housing on it. You did read the thread right?
#79 |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
Hmm, all of those gears minus the 1st are longer than in my 5 spd, but that 6th does look nice.....
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
#80 |
Every gear is shorter than the 5 spd with the 4.5 final. I regularly use 2nd to start because 1st is so short.
#81 |
So, if you've got an open gearbox anyway when replacing it, can't you drop out a gear or get a different one? My first gear is rather nice, goes to about 30 mp/h.
Shift to 5th at 100-105 mp/h though, so not too bad :)
#82 |
The gears as far as I know are not interchangeable. 5th gear in the 6 spd only goes about 145-150km/h and has the engine turning around 4100 rpm at 100km/h. Not ideal for every day use.
#83 |
No, that's a bit obnoxios indeed. I do 4000 rpm at 117 km/h GPS (so about 125-130ish clock) and 3500 rpm at 103/104 gps in 5th.
Never got to the v-max yet, I call game over after I've hit 63k in 3, 68k in 4 and then shift to 5th. 'cause honestly, all that does is increase the bill you get from the state. ;)
#84 | |
2ZR swap. DO IT! Ask how!
At this point, the only way to know for sure with the other gears is to get the parts and see if they fit. |
#85 |
Minor update
After going Boosted, I changed the gear lube to Royal Purple 75w-90 and it fix any problems I had with 4th gear. I now wish I had an option to swap in a lower ratio Final Drive as I have so much torque now on the highway to save even more fuel. Average is 6.0-6.3L/100km |
#86 |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
There is a lower final drive available for the c60 but good luck finding one, it was used on european mr2 spyders. I believe the final drive is 4.3.
2014 BSpec Divisional Champion |
#87 |
I've seen the options but nothing available in North America. Monkey Wrench Racing sells them and actually I can go to a 3.9:1 but the cost for me with exchange rate is way more than my whole transmission.
#88 |
I know a guy that has a link to euro c60's with high FD and LSD...$1000-ish, iirc
#89 |
![]() Yeah my C160 no LSD was $600 CND The 4.5FD was perfect for NA application but with the turbo it just revs unnecessarily high. |
#90 |
Sorry, I meant lower FD... I want to say 3.9
| Tags |
| 6 speed, conversion, gearbox, transmission |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
