New fog lights installed
Got a great deal on some fog lights that come with everything needed to make them work on ebay I got these for $38 with free shipping, just got them professionally installed for $100. I was going to install myself but just didn't want to deal with it. http://www.ebay.com/itm/JDM-06-09-TO...#ht_4557wt_975
http://www.midatlanticnostalgiaconvention.com |
![]() Drives: 2009 Toyota Yaris Sedan Join Date: Jul 2010
Nice! How are they at night? I need to get some.
They are bright enough for what they are! I'm overall pleased with them.
Form>Function
EBay fogs ftw that's where mine came from.
![]() ![]() Drives: 09 yaris hb Join Date: Jul 2010
if you don't like how bright they are, you could always put in some HIDs. i've had 55w ones in my ebay fogs for nearly 2 yrs no problems at all. lights up all over the place (Y)
#6 | |
Form>Function
I am planning on this too
jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
#9 | |
Form>Function
I heard the same ^
jqueza@microimage
damit thanks guys then going to have to dish out 100$$$
The fog lights themselves are identical. It is the plastic trim pieces that changed.
jqueza@microimage
thanks scott...
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
^---That's certainly one way to go. You can get the bezels separately on ebay all day long and for pretty cheap too.
Actually, looking again at the EPC, 2006-2011 Sedans are all the same for both the lights and the trim (and, that's how they are shown as well on MicroImage's listing):
http://shop.microimageonline.com/Fog...-foglights.htm
jqueza@microimage
are you sure ct dont want to spend 100 when i can spend 40$$
Yes. But, the difference between these $40 ones and the MicroImage $100 kit is that the MicroImage one includes the wiring pieces developed by Ray (1NZYaris1), which allow you to install them using the existing factory wiring through the firewall.
If you are installing them yourself this saves a large amount of work, as the $40 kit will require you to pull the battery and wiper tray to get at the firewall grommet to run the harness through the firewall. To modify the $40 kit to use the factory wiring you would need to purchase the two pins for the under-hood fuse panel connector ($12+ each) and the fog light relay for the under-dash fuse panel ($20).
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
| Installed my ebay sedan fog lights today and trd grill badge.... | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 9 | 11-20-2009 09:54 PM |
| fog lights, cost of installing them at the dealership? | kuyachris84 | Cosmetic Modifications (Exterior/Interior) | 33 | 05-24-2009 07:05 PM |
