![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2012
What oil do you guys use?
Like the title suggests, what do you guys run? Need to take it for an oil change sometime. I figured Pennzoil Platinum 5w20/30, since I figure Ultra might be an overkill for this engine, or Mobil 1 0/5w20/30. I run it for about 6-7k miles per year with 95% of my trips city and <5 miles. Thanks guys
Also might mention that I'm running on a fill of Maxlife, the car has about 89500 miles or so.
IMO for a DD, just use a qualty 5w-30 oil. I will get some flack for this but there is very little difference between major brands for their quality oils Don't believe the advertising hype . The key work here is "quality" oils.
BTW the "high mileage" oils siimply add some additional detergents to remove sludge. However it you change you oil regularly, there will not be any sludge to begin with . Last edited by RedRide; 07-28-2012 at 12:30 PM. |
Shell synthetic 5w-30 and 5w-20 . Here are some used oil analysises of the Shell synthetics from the '08 sedan . http://www.yarisworld.com/forums/showthread.php?t=38135 . Can get it for under $3.50 a quart ( includes tax ) . Here's another recent U.O.A. of Shell synthetic 5w-30 run to 12,000 miles in a '08 Prius , http://www.bobistheoilguy.com/forums...00#Post2694100 . Using the Platinum 0w-20 in the '11 FIT and it seems to like it . Use the Platinum 10w-30 and SHELL syn for the mowers and snowblower . The riding mower gets the 10w-30 Plat.. Then there are 3 push mowers . The Shell syn 5w-30 in 2 that are B.& S.. The 10w-30 Plat. in a Honda mower . The snow blower has Shell 5w-30 syn . Very little to no consumption of it . Depends on the mower . Also use the Platinum 10w-30 in a generator . Have faith in S.O.P.O.S. products for many years .
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
i used to use some expensive oil and mobi1 but now i just stick with toyota oil because of the price, only $4/L
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Mobil1 full synthetic 5W-30, in bulk it is only like $5 per quart. Super easy to DIY.
![]() ![]() Drives: 2008 toyota yaris Join Date: Mar 2011
castrol edge 5w-30
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
Ford Motorcraft 5w-20 synthetic blend (same oil as my Expedition).
Nic
Drives: 2008 3-Door Liftback Manual Join Date: Jan 2012
Castrol 5W-30. I will have to agree with RedRide. Any quality oil should work well. I have always used Castrol, so it is more of a habit than anything else.
Come to think of it, I need to change my oil. |
The cheapest namebrand synthetic 5w-30 I can find on sale - usually $25 for around 4.4 - 4.7L up here in Canda.
Sometimes it's Mobil 1, but usually it's Castrol Syntec or Pennzoil Platinum.
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
Royal Purple 5w30 Synthetic, every 5000 km.
Shush!
i use royal purple.. just because i like it... lol change every 10k... just did mine this weekend :-)
"Kids sure like the devil these days" ![]() |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
Toyota 5W30 from my dealer ... yes I know I am not mechanically inclined and wouldn't even think about changing my own oil. I know how to check it ... that's about as far as I will go.
Mobil1 Nov 1
Castrol GTX May 1
Have Yaris will travel.. |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
was mobil eco 0-20w every 5k with matching filter
now amsoil signiture eco 0-20w every 15k with matching filter
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
I change mine every 10k with Castrol Syntec 0w-30 European Blend. About $6/qt at Auto Zone, never had any problems.
![]() ![]() Drives: 2010 Yaris Sedan 4-DR Join Date: Apr 2012
mobil1 advanced fuel economy 0w-30 w/wix filter #51394 (just did first change 2700 miles ago)
| Tags |
| oil |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
| Synthetic Oil Questions. | Twistoffate0817 | General Yaris / Vitz Discussion | 19 | 07-15-2009 08:54 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
