Old 07-26-2012, 09:53 PM   #1
ViosFan
What oil do you guys use?
Like the title suggests, what do you guys run? Need to take it for an oil change sometime. I figured Pennzoil Platinum 5w20/30, since I figure Ultra might be an overkill for this engine, or Mobil 1 0/5w20/30. I run it for about 6-7k miles per year with 95% of my trips city and <5 miles. Thanks guys
ViosFan is offline   Reply With Quote
Old 07-26-2012, 09:55 PM   #2
ViosFan
Also might mention that I'm running on a fill of Maxlife, the car has about 89500 miles or so.
Old 07-27-2012, 06:35 PM   #3
RedRide
RedRide's Avatar
IMO for a DD, just use a qualty 5w-30 oil. I will get some flack for this but there is very little difference between major brands for their quality oils Don't believe the advertising hype . The key work here is "quality" oils.
BTW the "high mileage" oils siimply add some additional detergents to remove sludge. However it you change you oil regularly, there will not be any sludge to begin with .
Old 07-27-2012, 11:56 PM   #4
Hershey
Shell synthetic 5w-30 and 5w-20 . Here are some used oil analysises of the Shell synthetics from the '08 sedan . http://www.yarisworld.com/forums/showthread.php?t=38135 . Can get it for under $3.50 a quart ( includes tax ) . Here's another recent U.O.A. of Shell synthetic 5w-30 run to 12,000 miles in a '08 Prius , http://www.bobistheoilguy.com/forums...00#Post2694100 . Using the Platinum 0w-20 in the '11 FIT and it seems to like it . Use the Platinum 10w-30 and SHELL syn for the mowers and snowblower . The riding mower gets the 10w-30 Plat.. Then there are 3 push mowers . The Shell syn 5w-30 in 2 that are B.& S.. The 10w-30 Plat. in a Honda mower . The snow blower has Shell 5w-30 syn . Very little to no consumption of it . Depends on the mower . Also use the Platinum 10w-30 in a generator . Have faith in S.O.P.O.S. products for many years .
Old 07-28-2012, 12:33 AM   #5
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i used to use some expensive oil and mobi1 but now i just stick with toyota oil because of the price, only $4/L
Old 07-29-2012, 07:03 AM   #6
swidd
Drives: Yaris HB
Mobil1 full synthetic 5W-30, in bulk it is only like $5 per quart. Super easy to DIY.
Old 07-29-2012, 09:09 PM   #7
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
castrol edge 5w-30
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 07-29-2012, 11:17 PM   #8
PatrickJohnson
Drives: 2008 Yaris LB
+1
PatrickJohnson is offline   Reply With Quote
Old 07-30-2012, 01:17 PM   #9
tk1971
tk1971's Avatar
Ford Motorcraft 5w-20 synthetic blend (same oil as my Expedition).
tk1971 is offline   Reply With Quote
Old 07-30-2012, 10:27 PM   #10
Nicfin
Nic
Drives: 2008 3-Door Liftback Manual
Castrol 5W-30. I will have to agree with RedRide. Any quality oil should work well. I have always used Castrol, so it is more of a habit than anything else.
Come to think of it, I need to change my oil.
Nicfin is offline   Reply With Quote
Old 07-30-2012, 10:45 PM   #11
Viperoni
Drives: 2005 Toyota Echo
The cheapest namebrand synthetic 5w-30 I can find on sale - usually $25 for around 4.4 - 4.7L up here in Canda.
Sometimes it's Mobil 1, but usually it's Castrol Syntec or Pennzoil Platinum.
2006 Saturn Ion Redline
Old 07-30-2012, 11:33 PM   #12
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
Royal Purple 5w30 Synthetic, every 5000 km.
Old 07-30-2012, 11:37 PM   #13
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
i use royal purple.. just because i like it... lol change every 10k... just did mine this weekend :-)
Old 07-31-2012, 01:43 AM   #14
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Toyota 5W30 from my dealer ... yes I know I am not mechanically inclined and wouldn't even think about changing my own oil. I know how to check it ... that's about as far as I will go.
edmscan is offline   Reply With Quote
Old 07-31-2012, 03:14 AM   #15
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Mobil1 Nov 1
Castrol GTX May 1
Have Yaris will travel..
Old 07-31-2012, 11:39 AM   #16
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
was mobil eco 0-20w every 5k with matching filter
now amsoil signiture eco 0-20w every 15k with matching filter
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-31-2012, 12:48 PM   #17
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
I change mine every 10k with Castrol Syntec 0w-30 European Blend. About $6/qt at Auto Zone, never had any problems.
Old 08-02-2012, 11:17 PM   #18
Hershey
Some Wal-Marts have a $5 off instant rebate for the Platinum and Ultra . Theres' also a $10 mail in rebate from Pennzoil . Some states get a $10 Visa for Shell gas ( ? ) . Go here for rebate form to print out . http://www.pennzoil.com/rebate-form/ . Offer ends last of October .
oil
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
