Old 08-23-2012, 10:55 PM   #739
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The tooter results came in at +1 -1
And I think this was the latest list of guesses:
malibu +4 -6
Tooter +2 -3
Mazilla +1,000
Garm -5 -5
Anomaly +1 -3
Ljming -3 +3
BEEF +3 -2
Goldeenoh +5 -3
Goliath 0 0
tk-421 +4 -3
Yoda +4 +3
Jason -12 -18
packet +5 +3
Maitre +2 +4
Jeff -3HP -10TQ
Bluevitz-RS +4hp +6Tq
Scubaru Steve 0hp +10Tq
Flipper_1938 +6hp +4 ft lbs
Viperoni +2 -5
enviri +3hp 0tq
xnamerxx -10hp -10tq
CTScott -2hp +4tq
eTiMaGo 0 0
Billiam
+ 1,000,000
Looks like 4 people were a total of 2 digits off:
Anomaly
Goliath
enviri
Maybe we need to do a run off dyno.
Old 08-23-2012, 11:21 PM   #740
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Great read. I applaud the effort put into the manifold and testing it. I wouldn't be dissapointed at all, Ive seen reputable companies produce manifolds which proved power loss much greater. You have the right design aspects in your manifold design for the goals you had in mind. If I were to guess, a header will compliment that manifold simply because the volumetric efficiency of the intake has increased so much. You may not have a gain now because your setup is ''lopsided'', hiding the potential of the manifold.
As far as dyno conditions, that sheet clearly states the numbers are SAE corrected... which means temperatures and barametric pressure is accounted for. ( you can dyno on a 30 degree day, and on a 90 degree day, the numbers should theoretically be the same if SAE corrected).
VVT I on our cars learn, and change according to driving habit. I put my car on our dyno once with no changes, It made 28ft. lbs more torque, 6 less hp.........no changes. So I would deem your results inconclusive until you switch the manifold right on the dyno.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 08-24-2012, 12:32 AM   #741
well, it's a somewhat underwhelming result for the amount of work that went into it, but on the bright side, you haven't really lost power... and like others have said, it may well have major advantages once boost comes into play... So what are you waiting for, tooter? grab that turbo kit! :D
Old 08-24-2012, 01:06 AM   #742
tooter
play every day
tooter's Avatar
Thanks, man...
Considering that this was the very first attempt of a total amateur, the results weren't all that bad. I'm going to see if I can do better now.
There's already a header. This is what's on the engine when it ran today:
BLOX velocity stack air filter
Weapon R short ram intake
Weapon R 4-2-1 header
Micro Image center exit axle back exhaust
tooter manifold
Yes, the baseline was done at 80 degrees, and the second set of runs was at 88 degrees.
You know, maybe when I disconnected the ECU to relearn with the new manifold I didn't do enough flat out driving for it to learn the whole curve. I only floored it a couple of times on the freeway and thought it would be enough.
Old 08-24-2012, 02:54 AM   #743
tooter
play every day
tooter's Avatar
I didn't really do all that much work, because it's actually a pretty simple straightforward process to visualize a concept and make it a reality. The total elapsed time from getting the first manifold to running a complete operating prototype on my engine only took 2 months.
That's true. The difference in power is to small to actually feel. You could only quantify it by going flat out on a timed drag strip.
I'm going to stay on the normally aspirated path. Even though the dyno runs reveal the manifold's shortcomings at full throttle, in normal partial throttle low rpm everyday driving conditions it works really good.
Old 08-24-2012, 07:31 AM   #744
Disappointing numbers...but at least you tried. For that, I applaud you.
Old 08-24-2012, 08:20 AM   #745
anomoly40
Depot Damager
Drives: '08 Liftback
Anomaly
Goliath
enviri
But I got one right...
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 08-24-2012, 10:49 AM   #746
You drove it the way you drive the car, which was a more exact "before and after".
I don't think 'driving style' can change the maximum power output on the dyno anyway, but it might change the curve some.
Old 08-24-2012, 12:19 PM   #747
tooter
play every day
tooter's Avatar
The whole process has been a lot of fun, and I'm not quite done playing around with it yet.
Old 08-24-2012, 02:18 PM   #748
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Time to have the shop make you a adapter for a corolla TB :)
I got my corolla TB yesterday. I'm going to buy an xB weapon R intake manifold and have the TB flange modified to fit it.
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-24-2012, 03:02 PM   #749
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Why not purchase the Micro Image manifold with the 1ZZ TB flange already on it?
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 08-24-2012, 03:13 PM   #750
4/20 NEVER FORGET
When is it going to be available for purchase? If it was I would have already purchased it
Old 08-24-2012, 03:16 PM   #751
Jeff@MicroImage
"Know it all"
Very soon, we have a prototype to dyno and if all looks good we'll begin production.
Old 08-24-2012, 03:49 PM   #752
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
does it come in red?
Old 08-24-2012, 04:05 PM   #753
tooter, once you get a bigger resonator-to-axleback exhaust piece, youll likely feel better gains all over
Old 08-24-2012, 05:17 PM   #754
tooter
play every day
tooter's Avatar
The CNC guys at Origin Design can make an adaptor for any throttle body. How is the Corolla throttle body configured differently from the Yaris one?
Old 08-24-2012, 05:18 PM   #755
It bolts right on, it has a little larger throat.
Old 08-24-2012, 05:18 PM   #756
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It has a bigger opening, nothing more. same bolt pattern, it's a direct bolt on. You'd just need a bigger opening on the adapter
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
