#721 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I'm with xnamerxx, Turbo set up will benefit the most, especially for systems that are going beyond the 20 or so psi (I think that is the number i remember reading) that the plastic box limits it's self to. either way still a cool product.
can we get a re post of the guesses to see how close everyone was. I don't even remember what i had put.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#722 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Good job on seeing that project through. It was a lot of fun to watch.
Next you should swap the TB to a Corolla throttle body :) |
#723 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
would you mine doing an other dyno run..without the 90 degree....and so just the velocity stack....it wont hurt the car for just a dyno run :P or maybe but a net around it
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#724 | |
#725 |
lol no
thats why I asked would you mind to....
#726 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
I still applaud you for getting it out of your head and onto the car
#727 |
#728 |
Good effort, too bad it didn't make more power. A mad props for going beginning to end on it :)
#729 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
So I win? I got hp right and was off 2 torques.
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#730 |
play every day
Here's a comparative chart of the best of the basline runs and the best of the tooter runs...
#731 | |
play every day
![]() Remember that the dyno runs are at wide open throttle and I don't normally drive at wide open throttle. I just drive like a regular transportation driver. And at under partial throttle conditions and low rpms the tooter manifold does perform great. In fact that was one of the things I was most concerned about, whether it would be driveable under normal everyday conditions. I still need a few more fillups with the tooter to get an accurate comparison to the baseline gas mileage average.
#732 | |
#733 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Damn bittersweet ending...thanks for putting the effort out there to find out.
I wonder if could aggressive tuning n/a could make gains along with a larger tb?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#734 |
Obsessed with 1.5L
Actually...some of that low end loss could be due to the supershort intake
I wonder a long intake into the fender well could make magic happen? I know you have flooding issues so thats a no go for you
#735 | |
play every day
Well, that's why I did comparative dyno runs, because they accurately show the difference. Under the partial throttle conditions of normal driving the difference isn't noticeable. If your gas pedal is to the floorboard all the time you're driving then you could notice the difference.
#736 | |
play every day
![]() That intake is as physically short as possible to fit the filter. I might try a longer cold air intake just to see what happens. I can always take it off during the wet season. I'm not done experimenting yet. ![]() Harry, at the HK Motorsports Dyno Shop in Van Nuys said that he'd open his place on a Sunday for a $70 Dyno Day if there are at least 5 cars to run. I'm going to post this in the California section just to see if anyone is interested. |
#737 |
play every day
The tooter results came in at +1 -1
And I think this was the latest list of guesses: malibu +4 -6 Tooter +2 -3 Mazilla +1,000 Garm -5 -5 Anomaly +1 -3 Ljming -3 +3 BEEF +3 -2 Goldeenoh +5 -3 Goliath 0 0 tk-421 +4 -3 Yoda +4 +3 Jason -12 -18 packet +5 +3 Maitre +2 +4 Jeff -3HP -10TQ Bluevitz-RS +4hp +6Tq Scubaru Steve 0hp +10Tq Flipper_1938 +6hp +4 ft lbs Viperoni +2 -5 enviri +3hp 0tq xnamerxx -10hp -10tq CTScott -2hp +4tq eTiMaGo 0 0 Billiam ![]() + 1,000,000 Looks like 4 people were a total of 2 digits off :Anomaly Goliath enviri eTiMaGo Maybe we need to do a run off dyno.
#738 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Great read. I applaud the effort put into the manifold and testing it. I wouldn't be dissapointed at all, Ive seen reputable companies produce manifolds which proved power loss much greater. You have the right design aspects in your manifold design for the goals you had in mind. If I were to guess, a header will compliment that manifold simply because the volumetric efficiency of the intake has increased so much. You may not have a gain now because your setup is ''lopsided'', hiding the potential of the manifold.
As far as dyno conditions, that sheet clearly states the numbers are SAE corrected... which means temperatures and barametric pressure is accounted for. ( you can dyno on a 30 degree day, and on a 90 degree day, the numbers should theoretically be the same if SAE corrected). VVT I on our cars learn, and change according to driving habit. I put my car on our dyno once with no changes, It made 28ft. lbs more torque, 6 less hp.........no changes. So I would deem your results inconclusive until you switch the manifold right on the dyno.
Ptuning.com |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
